Author Topic: xbee to xbee/ ardiuno problems using x-ctu  (Read 1478 times)
Offline ATRmakerTopic starter
« on: September 29, 2011, 09:34:20 AM »
Hi
I new at this , but i can't get any communication between by xbee devices
i'm am using ladyada tutorial
The problem is this :
 Action required. Unable to communicate with modem. verify com  port with action below
XBEE:
press and release reset switch.
dialog box should close within 10 seconds
THANKS
FOR ANY HELP
Offline joe61
Re: xbee to xbee/ ardiuno problems using x-ctu
« Reply #1 on: September 29, 2011, 01:18:18 PM »
Do you have the right firmware loaded? One of them has to have the controller firmware, and the other the slave. I don't recall the right terms off the top of my head but ...
Joe
  • Helpful? 84
« Reply #2 on: September 29, 2011, 07:46:15 PM »
Which XBees? There are several hardware modules and protocols.
Give the Series # and the Firmware Version # as reported by the Query command in X-CTU.
« Reply #3 on: September 29, 2011, 08:55:44 PM »
Xbee series 1 ,
when i get to test and query it says
due to this i can't get the firmware version
http://www.ladyada.net/make/xbee/configure.html
« Reply #4 on: September 29, 2011, 11:25:22 PM »
I figured out the problem, there was an error with the adapter
Thanks for all your help
Offline Gertlex
  • Helpful? 23
« Reply #5 on: September 30, 2011, 01:25:52 AM »
Thread is useless without what adapter and what the problem with adapter/solution was. :)
I
XBee
Started by Cornelam Software
Last post June 12, 2010, 11:03:44 PM
by lhy_L_P
Last post January 11, 2009, 01:57:59 PM
by Magnus
Last post January 23, 2009, 08:13:46 AM
by flimflap
Last post June 15, 2011, 07:14:04 AM
