Author Topic: Bitwise Operations  (Read 601 times)
Offline spizzakTopic starter
Bitwise Operations
« on: October 01, 2011, 04:59:25 PM »
I was reading through the $50 robot code and there's a line I don't understand.
TCCR1B = (1 << WGM13) | (1<<WGM12) | (1 << CS11);
WGM13, WGM12, and CS11 are all single bit registers as far as I can tell. Therefore either 1 or 0. If they are 1 then all those shifts are just shifts of one and then this line looks like the equivalent of (0b10 | 0b10 | 0b10) = 0b10.
Can someone please explain where I'm going wrong?
Offline rbtying
  • Helpful? 31
Re: Bitwise Operations
« Reply #1 on: October 01, 2011, 06:36:57 PM »
I'm not exactly sure what you mean by a single bit register (usually registers are 8 bits, and bits are 1 bit...)
If you read the datasheet you'll realize that WGM13, for example, is an offset which, when shifted, gives the corresponding bit in the TCCR1B register.
I think you should rephrase to "WGM13, WGM12, and CS11 are all single bits in registers".
Offline joe61
« Reply #2 on: October 01, 2011, 09:07:02 PM »
These identifiers are preprocessor macros. The preprocessor is a program that runs before the compiler and does text substitution on things that are in the code like
#define FOO bar
In this case, every time FOO shows up in the source code, it will be replaced by bar, and then the compiler will see bar (not FOO). The macros above are defined in a header file (which one depends on the model of avr being used). the processor expands TCCR1B to the address of that register. It expands the WGM* macros to the number of each bit. So given the following
TCCR1B = (1 << WGM13) |= (1 << WGM12);
The preprocessor first converts TCCR1B to a register address. Then it converts WGM13 & WGM12 to their bit numbers within TCCR1B.
The compiler then sees something like
0x2f = 8 | 4;
So bits 4 and 3 get set in the byte located at 0x2f.
Joe
« Reply #3 on: October 02, 2011, 02:02:57 PM »
You're right that is what I meant to say, and I realize that they are offset in the register but that doesn't really change the fact that it's a single bit of data.
What Joe is saying, makes sense though. I didn't realize that they were macros. Anyway, I'll stick to giving the registers a binary number, but that does clear things up.
Thanks guys
« Last Edit: October 02, 2011, 02:06:29 PM by spizzak »
Last post April 22, 2011, 07:29:53 PM
by TrickyNekro
