Author Topic: To prevent load from slipping on incline  (Read 499 times)
Offline AbhimanueTopic starter
« on: October 02, 2011, 05:58:20 AM »
I need to move my bot over a slope of 17 degrees with a load on it. Can u suggest some possible ways of preventing the load from slipping off the robot when on slope. I can't make a permanent embankment around it as the load has to slide out of the robot later.
Offline rbtying
  • Helpful? 31
Re: To prevent load from slipping on incline
« Reply #1 on: October 02, 2011, 08:20:17 AM »
Put a servo behind the load, and raise it when going up the slope. You can later lower it when you need to slide the load off.
Offline garrettg84
  • Helpful? 8
  • Armchair Roboticist Extraordinaire
« Reply #2 on: October 02, 2011, 06:07:12 PM »
How about keeping it simple and adding straps or a rim/bucket style design to the bot?
-garrett
Offline Fr0stAngel
  • [O_O] what??
« Reply #3 on: October 03, 2011, 10:53:55 AM »
Consider the above image.... introduce an incline of 10-15 degrees on the carrier part of your robot. that way when it will be climbing, load will still be almost parallel to the ground... when descending , the load will be stopped by the front rim.
(yes i drew it on paint, and i'm not much of a paint pro  :P)
on a side note. 17 degrees is not much of an incline though, if there is sufficient friction between your load and robot surface, it won't slip.
'crazy' is the new hype! =)
Last post June 07, 2009, 11:58:26 PM
by Metal Slug 2
Last post May 19, 2012, 03:50:17 PM
by Eithman
Last post September 30, 2012, 10:04:25 PM
by Mastermime
Last post December 01, 2012, 04:17:15 AM
by sys 49152
