Build started 5.10.2011 at 01:37:27I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT TESTTPA.o -MF dep/TESTTPA.o.d -c ../TESTTPA.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [TESTTPA.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT lib_hardware.o -MF dep/lib_hardware.o.d -c -Os ../lib/lib_hardware.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [lib_hardware.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT lib_timers.o -MF dep/lib_timers.o.d -c -Os ../lib/lib_timers.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [lib_timers.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT opt_pcint.o -MF dep/opt_pcint.o.d -c -Os ../lib/opt_pcint.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [opt_pcint.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT gen_clock.o -MF dep/gen_clock.o.d -c -Os ../lib/gen_clock.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [gen_clock.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT opt_TimerCompare.o -MF dep/opt_TimerCompare.o.d -c -Os ../lib/opt_TimerCompare.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [opt_TimerCompare.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT opt_TimerCapture.o -MF dep/opt_TimerCapture.o.d -c -Os ../lib/opt_TimerCapture.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [opt_TimerCapture.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT opt_scheduler.o -MF dep/opt_scheduler.o.d -c -Os ../lib/opt_scheduler.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [opt_scheduler.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT lib_iopins.o -MF dep/lib_iopins.o.d -c -Os ../lib/lib_iopins.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [lib_iopins.o] Error 127 (ignored)I"C:\MyRobot\Test_TPA\..\WebbotLib 2" -mmcu=atmega640 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT opt_TimerOverflow.o -MF dep/opt_TimerOverflow.o.d -c -Os ../lib/opt_TimerOverflow.c/usr/bin/sh: IC:\MyRobot\Test_TPA\..\WebbotLib 2: command not foundmake: [opt_TimerOverflow.o] Error 127 (ignored)mmcu=atmega640 -Wl,-Map=TESTTPA.map TESTTPA.o lib_hardware.o lib_timers.o opt_pcint.o gen_clock.o opt_TimerCompare.o opt_TimerCapture.o opt_scheduler.o lib_iopins.o opt_TimerOverflow.o -L"C:\MyRobot\WebbotLib 2" -lWebbot-ATmega640 -lm -lc -o TESTTPA.elf/usr/bin/sh: -Wl,-Map=TESTTPA.map: command not foundmake: [TESTTPA.elf] Error 127 (ignored)avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock -R .signature TESTTPA.elf TESTTPA.hexavr-objcopy: 'TESTTPA.elf': No such filemake: *** [TESTTPA.hex] Error 1Build failed with 1 errors and 0 warnings...
Anyway, seems now that I have a problem with the Axon2 I2C pins...is it possible to use other pins as I2C?
I'd like to use the AVR Studio 5 since I feel more comfortable with Visual Studio "look and feel", but it needs a lot of tweaking before you can actually use it, and I am not sure whether Axon "likes" it...
Started by JoseS13 Software
Started by nda2230 Software
Started by Hero I Software
Started by ArnoldC Software
