Author Topic: Where do you guys buy your connectors?  (Read 808 times)
« on: October 06, 2011, 08:12:07 PM »
Hi guys,
I am building a robot that is using the Axon II as the microcontroller product.  To connect something such as a GPS module, I would use a Hitec male connector, right?  Where do you guys buy your connectors from?
Offline joe61
Re: Where do you guys buy your connectors?
« Reply #1 on: October 06, 2011, 09:07:06 PM »
I get mine either from DigiKey (Molex connectors) or Pololu. Pololu has some pretty cheap housings ( http://www.pololu.com/catalog/category/19 ), and also sells Futuba/JR connection kits (bottom of that page).
Also see the connector tutorial here http://www.societyofrobots.com/electronics_wire_connector.shtml
Joe
« Reply #2 on: October 08, 2011, 03:25:12 PM »
So which of these from sparkfun will work for connecting to the Axon II?
http://www.sparkfun.com/search/results?term=molex&what=products
Edit:  Do only hitec male connectors work with the Axon II?
« Last Edit: October 08, 2011, 03:51:03 PM by Mastermime »
Offline joe61
« Reply #3 on: October 08, 2011, 04:52:03 PM »
From the datasheet it looks like that Axon will accept any standard servo type connector with power in the middle, ground on one side and signal on the other.
I generally find Sparkfun a bit pricey, but any three pin housing with good crimp pins and .1 inch spacing should be fine. Futuba, JR, Hitec, Molex, whatever.
I say "good crimp pins" because I've gotten some bulk pins in the past that didn't grip the pins on the board well, and the connector kept coming loose. I never had that problem with the JR, Moles or Hitec connectors though.
  • Helpful? 107
« Reply #4 on: October 09, 2011, 07:07:50 AM »
These are also useful as you they are already crimped and in a housing http://www.pololu.com/catalog/category/65
Just decide on length and whether you want male-male, male-female or female-female
« Reply #5 on: October 09, 2011, 05:52:45 PM »
Ok I'll probably go with the product that's in the link Webbot posted.  If I just need the connectors to connect to the Axon, I will need the male-male connector and then cut one of the male headers off, right?
« Last Edit: October 09, 2011, 06:14:26 PM by Mastermime »
  • Helpful? 107
« Reply #6 on: October 09, 2011, 07:37:48 PM »
The Axon has header pins your wires will need female sockets. The other end of the wire depends on what you are connecting to. But female-female is most likely what you need. If you can afford then also by some male-male. You can then combine the two ( ie female-female + male-male = female-male) to give you all  alternatives.
« Reply #7 on: October 09, 2011, 08:02:57 PM »
Ok thank you for your help Webbot. By the way, Project designer/ Webbotlib is absolutely brilliant!  It has saved me loads of time and I also want to thank you for that  :)
Last post June 30, 2008, 10:16:51 AM
by Asellith
Last post December 13, 2008, 08:11:22 AM
Last post January 15, 2009, 09:35:46 AM
by airman00
Last post March 24, 2009, 04:31:42 PM
by Its_Friday
