Author Topic: Center of gravity for three wheeled robot  (Read 1037 times)
Offline MCTopic starter
« on: October 10, 2011, 01:44:27 AM »
I would like to know how to calculate the centre of gravity for three wheeled robot
I have attached an image of the triangle and shown the center of gravity.
Please let me know if the formula is right or should it be the other way round. i need to cal the weight on the three wheels when loaded and unloaded.
Re: Center of gravity for three wheeled robot
« Reply #1 on: October 11, 2011, 02:59:27 PM »
You can't calculate the CoG for the finished robot by calculating it for just the two dimensional form. but for a triangle, the point will be where the medians meet.
For a finished robot with batteries and all, you can ue three weight scales, one under each wheel (or a single if you can make the remaining wheels level with the scale surface at each measurement), to see how the weight distributes, but this is still in 2D and the Z-axis (upwards from where it stands) is just as important when the robot moves.
It's much more involved to find the 3D CoG.
Offline Gertlex
  • Helpful? 23
« Reply #2 on: October 16, 2011, 10:42:30 PM »
3D CoG can be done my weighing the bot while its tilted a known amount (aka angles via knowing height of the wheels) and doing some amount of math... I've not done it personally, but that's how I've seen CG height determined before.
I
Last post July 26, 2008, 04:58:05 PM
Last post August 20, 2008, 06:26:22 PM
by steferfootballdude13
Last post March 28, 2009, 12:36:29 PM
by jamort
Last post November 26, 2009, 08:24:33 PM
