Author Topic: [advertisement] 2, 3, & 4 Function Joysticks at ServoCity  (Read 694 times)
Offline ServoCityTopic starter
« on: October 10, 2011, 08:14:39 AM »
ServoCity carries joysticks! Our joysticks are extremely versatile and can be used in a wide variety of applications!
2 Function Joystick (Standard) - $19.99
The R-200 joystick is perfect for 2 position applications. It offers 50° of total tilt on both the X and Y axis. Each axis is coupled with 5K potentiometers. Both potentiometers have individual neutral adjustments. Internal springs center the joystick back to neutral (center).
Resistance Value: 5K
Resistance Tolerance: +/-20%
Independent Linearity: +/-1%
Resolution: Essentially Infinite
Temperature Coefficient Resistance): +/-400 ppm/ C°
Output Smoothness: 0.5% Maximum
X/Y Axis Electricity Corner: +/-25°
Z Axis Electricity Corner: N/A
Insulation Resistance: 50M @ 500VDC 60 sec.
Restoration Error Rate: +/- 0.03K
Prolepsis Mechanical Life-cycle: 500,000 cycles
Operating Temperature Range: -10° to 80° C
Operate Torque: 90gf (X), 250gf (Y)
2 Function Joystick (Thick Stick) - $19.99
The R-204 joystick is perfect for 2 position applications. It offers 50° of total tilt on both the X and Y axis. Each axis is coupled with 5K potentiometers. Both potentiometers have individual neutral adjustments. Internal springs center the joystick back to neutral (center). This joystick has the same specifications as the R200MB2, but the diameter of the stick is slightly thicker measuring 0.473” (12mm).
2 Function Joystick (Ball Stick) - $19.99
3 Function Joystick (Standard) - $29.99
Z Axis Electricity Corner: +/-25°
Operate Torque: 90gf (X), 250gf (Y), 330gf (Z)
4 Function Joystick (Standard) - $34.99
Z Axis Electricity Corner: +/-45°
To view ServoCity's selection of joysticks online, visit: http://www.servocity.com/html/joystick_modules.html
« Last Edit: October 15, 2011, 10:12:07 AM by Admin »
Last post October 07, 2011, 01:20:24 PM
by ServoCity
Last post October 19, 2011, 02:51:03 PM
by ServoCity
Last post January 03, 2012, 11:10:31 AM
by ServoCity
Last post January 04, 2012, 10:33:06 AM
by ServoCity
