Author Topic: hi and all that...robo design aide...  (Read 753 times)
Offline eTagTopic starter
« on: October 21, 2011, 01:16:04 PM »
first off this is my first post so i want to say "hi all" and let you all know that i have done some electronics tinkering in the past but that it has also been a few years and much has changed...
second...i have been trying to find out how probable it would be to use a desktop pc's cpu and ram with a solid state hard drive for a...? robot "motherboard"?
i've tried google and wiki's but neither give me anything. they all come up with various things about the hexibot.
also i'm not trying to use an entire pc motherboard...but just the cpu, ram, and a hard drive.
any input would be helpful. and yes i understand that this would be difficult to do and that there are certain energy and size requirements involved...but that is not the information i'm looking for...what i need is to know if it is possible to replace a controller with these items?
car-comp-car-comp-car-comp
calimods.com
I work on cars and I love computers
robots seems like the best convergence of the two.
  • Helpful? 84
Re: hi and all that...robo design aide...
« Reply #1 on: October 21, 2011, 06:53:19 PM »
It can be and has been done. There also have been a few threads in these SoR forums.
Did you search here?
« Reply #2 on: October 21, 2011, 09:10:59 PM »
As long as you get all the needed parts and are able to make a multilayer PCB that is designed for microwave technology you could, but do have a look at this if you're serious about it.
« Reply #3 on: October 22, 2011, 01:29:49 AM »
thanks....not looking to make one that small but still got some good info...
i've heard the term multilayer several times now...will someone kindly define this in the terms of motherboards?
calimods.com
« Reply #4 on: October 22, 2011, 05:11:00 AM »
Imagine a stack of PCB's all glued together on top of each other and connected in between the layers and you're pretty close.
The "smallest" version is like a dual sided PCB with a layer in the middle where you can have traces going back and forth in directions that's impossible relative to the top or bottom layer. or it could be a single (or several interconnected) ground plane to isolate the top and bottom from each other (noise wise).
So, instead of a single carrier with copper on each side, you have a sandwich with one or more layers of copper in between.
copper
carrier
copper
carrier
copper
(etc).
« Reply #5 on: November 11, 2011, 09:19:33 PM »
thanks...thats what i was thinking...but it's always better to ask and learn then assume and make a mistake...
calimods.com
Last post October 29, 2006, 10:27:16 PM
Last post October 15, 2006, 09:47:17 AM
by Gopher
Last post December 21, 2006, 09:07:02 PM
by Militoy
Last post February 17, 2008, 11:54:26 AM
