Author Topic: Where to buy a High Current Allowing Switch?  (Read 2155 times)
Re: Where to buy a High Current Allowing Switch?
« Reply #30 on: January 08, 2012, 01:03:36 AM »
Your switch should go to terminal #85 as in your drawing, however, your switch connects this terminal to ground!!! It should connect it to B+
I dont understand what you mean.  Lets just make sure our terminology is the same. B+ stands for "battery positive", right?  So are you saying the switch connects in between the fuse holder and terminal 30?
« Reply #31 on: January 08, 2012, 03:43:54 PM »
Yes.
« Reply #32 on: January 08, 2012, 03:58:45 PM »
Ok thanks for your help!
« Reply #33 on: January 28, 2012, 05:48:37 PM »
Ok I just tested my circuit out and everything went well except for one thing.  The LED built into my rocker switch is on even when I switch the circuit off.  Is this how rocker switches are designed or did I hook something up incorrectly?
« Reply #34 on: January 28, 2012, 05:55:16 PM »
There must be thousands of lighted rocker switches on the market and every thinkable way of connecting an LED into them will be represented, so maybe yes, maybe no.
Hint: The more info you provide, the better we can help.
« Reply #35 on: January 28, 2012, 10:10:37 PM »
Here is the switch I bought http://www.amazon.com/gp/product/B001TQKKMC/ref=oh_o03_s00_i00_details
This is what it looks like on the side of the switch and then below I put where I connected the terminals.
+          A        Ground
T         12v
E         B
R         A
M         T
I          T
N         E
A         R
L         Y
8
5
EDIT: I SOLVED THE ISSUE.  WHAT I HAVE ABOVE SHOULD BE FLIPPED
« Last Edit: January 28, 2012, 10:28:55 PM by Mastermime »
« Reply #36 on: January 30, 2012, 08:13:35 AM »
Great :)
Last post November 30, 2007, 05:23:16 PM
Last post December 19, 2007, 04:17:10 PM
by airman00
Last post July 09, 2010, 05:05:18 PM
by madsci1016
Last post September 08, 2012, 07:33:44 PM
