Author Topic: WALL WARTS AND LOW DC CURRENTS  (Read 872 times)
Offline shyamgeniousTopic starter
  • TECHNO GEEKS AND SCIENTISTS ROCK BUT DO YOU??
« on: October 25, 2011, 12:10:14 AM »
IVE GOT A WALL WART WITH FOLLOWING SPECIFICATIONS
INPUT:100-240V=50-60Hz
OUTPUT:12VDC 1A
AND THE WARNING FOR USE WITH INFORMATION TECHNOLOGY EQUIPMENT ONLY !
CAN I USE IT FOR OTHER PURPOSES LIKE USING IT AS A BATTERY WITH CONTINUOUS VOLTAGE TO RUN SMALL THINGS LIKE TOY MOTORS AND LEDS??
COULD I ATLEAST HOOKUP A CPU COOLER FAN OF SPECIFICATIONS
NOISE LEVEL 16DBA
FAN SPEED 2500-2800 10% RPM
FAN DIMENSIONS 80X80X25 MM
REGARDS
SHYAMGENI
(JR ROBOT)
The wise only need a hint to know whats going on.The fools cannot understand even if its given in writing.You decide-
 which are you?
regards,
ShyamGenious
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
Re: WALL WARTS AND LOW DC CURRENTS
« Reply #1 on: October 25, 2011, 12:23:54 AM »
You can use it for anything that runs on 12V and does not consume more than 1A.
« Reply #2 on: October 25, 2011, 12:28:14 AM »
THATS A VERY STRAIGHTforward answer! ??? ??? ???i wante dto know wether i could use it for smaller things like bulbs and leds and motors all less than 2volts!not INCLUDED IN "IFORMATION TECHNOLOGICAL USES".
« Last Edit: October 25, 2011, 12:31:16 AM by shyamgenious »
 which are you?
regards,
ShyamGenious
« Reply #3 on: October 25, 2011, 10:24:15 AM »
And 100% correct :)
An LED is (sort of) information technology - it can inform you if a piece of equipment is on or similar.
You shouldn't worry too much over the "for IT only" sentence. That's a way to avoid lawsuits if someone use it eg. medical use and someone dies, or if it's taken outdoors and shorts out etc.
It will drive a 12V bulb of max. 12W.
With a series resistor of 470 Ohms to 2.2 kOhm, it can drive an LED.
Lower than 12V bulbs can be driven in the same way, if the correct series resistor is calculated, but then the resistor has to be able to sustain the current without burning.
You could make a variable regulator, following the output, with an LM317 to get a variable output voltage from ~1.25V to around 9V.
Please lay off the CAPS LOCK key, no reason to yell!
« Reply #4 on: October 26, 2011, 10:05:22 PM »
thanks!!! a lot!! but please tell me how to hookup coz my multimeter is not available and ther are two wires stcking out.could you please draw a circuit diagram ?? ??
 which are you?
regards,
ShyamGenious
  • Helpful? 45
  • N.I.R.
« Reply #5 on: October 27, 2011, 01:02:33 AM »
You should read some tuts on basic electronics before setting something on fire. Have a play with Circuit Simulator to get better understanding (under Circuits menu You get to choose different diagrams; if you Right Mouse Click inside the simulator window - other components can be added).
I hope You do understand that one wire is Positive(+) and the other wire is Ground(0) - same as terminals of the battery - one + and one 0.
« Reply #6 on: November 29, 2011, 08:18:42 AM »
silly i know the symbols im not an absolute nut i need the color schemeatics for the wires in reference to my country,india
 which are you?
regards,
ShyamGenious
  • Helpful? 45
  • N.I.R.
« Reply #7 on: November 29, 2011, 11:18:56 AM »
Wires for what?
« Reply #8 on: November 29, 2011, 05:25:19 PM »
Perhaps you should read your own footer...
 which are you?
Yes, based on your posts in this thread, I think any reader have decided which you are ;)
Read some tutorials on your subject, then experiment and if you have any questions, please try to sound coherent, because your posts doesn't make sense as is.
Offline Redcap
  • Helpful? 11
« Reply #9 on: November 30, 2011, 05:14:08 AM »
I take it you've removed the metallic end plug, and are now left with a wall wart that has a 2 wires going out of it to nothing.
What color are the wires? (If you're lucky, one will be red, the other black.)
No one's calling you a nut  ;D But simply trying to gauge the level of your knowledge in regards to electronics  ;)
In hindsight, it may have been a better option to leave the metal plug bit on it, and buy a jack to plug it into for your project/s (as in most cases it'll have shown on the wall wart the Ground and the Positive in relation to the metallic plug)
Last post November 13, 2007, 12:45:35 PM
by Half Shell
Last post March 12, 2008, 07:34:51 AM
by cooldog
Last post July 20, 2008, 07:58:51 PM
by HDL_CinC_Dragon
Last post April 09, 2008, 09:50:35 AM
by benji
