Author Topic: Sensor fusion  (Read 419 times)
Offline kasuntTopic starter
Sensor fusion
« on: October 25, 2011, 03:40:16 AM »
Im wondering if someone here is able to provide me with some info on sensor fusion.
I have a differential drive robot with a 360 degree IR sensor network (14 IRs in total) and two encoders.
I can provide more information if needed but all I want to do is fuse both the encoder and the IRs to provide the heading.
I think a technique called weighted average is quite simple but im not able to find any useful documentation on this.
Thanks in advance
Offline peterb
Re: Sensor fusion
« Reply #1 on: November 03, 2011, 02:28:25 PM »
Hello,
About "weighted average".
Probably this is it:
Let's say, that you have two inputs: x and y (x, y are numbers).
We need two other numbers (the "weights"), let them are a and b.
Weighted average of x,y is the next: (a*x + b*y)/(a+b)
The normal average is (x+y)/2, where the x and y are equally "important".
With weighted average, you can make one of x and y more "stronger" than the other. The stronger input will influence the output more.
Now back to your question:
You have three inputs: IR, E1 and E2 encoders.
Let us say, that you counted the headings from the inputs : hIR, hE1,hE2, for example:
hIR=60, hE1=50, hE2=52 (grads).
The average will be (60+50+52)/3=54, so your robot's head is in 54 grad.
But, you experimented, that the encoders are not as good as you planned, so you should make the IR inputs stronger:
(2*60+1*50+1*52)/(2+1+1)=55
Now your problem is, which numbers should you use as weights.
Last post March 26, 2008, 03:06:36 PM
by AndrewM
Last post November 18, 2010, 09:53:05 PM
by Redcap
Last post June 16, 2012, 08:50:16 AM
by firatdede
Last post January 23, 2013, 01:02:10 AM
by drofan
