Author Topic: Tips on Building Arduino Robot  (Read 1210 times)
Offline ecerobotTopic starter
« on: October 26, 2011, 11:43:24 PM »
Things you need to build an Arduino Robot
1) Platform -Body
2) Arduino microcontroller - Brain
3) Sensors -sensitivities
Let's first talk about Platform
There are all kinds of platforms in the current market, mostly there are five kinds:
1)2WD (Two wheel driving robot platform)
2)4WD (Four wheel driving robot platform)
3) Tracked Robot (looks like a small tank)
4) Robot Legs
5) Robot Arms
Note: You might wanna check this robot website:www.ecerobot.com It also provides some great Arduino example codes for beginners.
Secondly, Arduino microcontroller
1)Arduino UNO
2)Arduino Mega 2560
3)Arduino ADK
For most of time, people attach an expansion shield on the top of microcontrollers to make the wire connections easier. Connect microcontrollers to sensors by using 3p Jumper wires
Arduinio MEGA 2560 is strongly suggested.
Since it has 54 digital input/output pins (of which 14 can be used as PWM outputs) and 16 analog inputs, which can carry more sensors and make your robot acts more dynamic.
The last but not the least – Sensors
Arduino Sensors
Digital Temperature Sensor
Dual-Axis Joystick
MQ-2 Gas Sensor
Relay Module
Big Button Module
RB URF v1.1 Ultrasonic Sensor
Virbration Sensor
Buzzer Module
Mini IR Detector Photoelectric Sensor
Mini IR Line Tracking Sensor
Magnetic Sensor
IR receiver Sensor
IR Transmitter Sensor
One-way Tilt Sensor
Light Sensor
IR Wireless Remote Kit
MQ-3 Gas sensor(Ethanol)
Analog Voltage Divider
Digital LED Module
Infrared Pyroelectricity Sensor
Triple Axis Accelerometer
DHT11 Temperature and Humidity Sensor
Flame Sensor
Analog 300 Rotation Sensor
WiiChuck Adapter
Bumper Switch
Check over at www.ecerobot.com and find out the right sensors for your robot
Offline wise318
Re: Tips on Building Arduino Robot
« Reply #1 on: October 27, 2011, 10:52:08 AM »
Hi can you describe the connection of the mega 2560 , it seems lacking and i think the difficult part is the connection and make 2 motor run. I ve got mega 2460 and sabertooth intend to drive 2 dc motor . Howeer now i stucked and seems no one can answer my post.
I would appreciate if you can show the connection and how you drive 2 motor with aeduino mega 2560 . Greatly appreciate your sharing here
This the photo attached , I have not done the wiring and checking with the society here :)
« Last Edit: October 27, 2011, 10:56:51 AM by wise318 »
Last post March 03, 2009, 06:12:39 AM
Last post February 18, 2012, 11:49:19 PM
by aidan
Last post May 06, 2012, 09:42:07 PM
by Gertlex
Last post February 28, 2013, 10:35:09 AM
by dell341
