Author Topic: PCB:positive vs negative  (Read 2741 times)
Offline bobthefirst1Topic starter
« on: October 27, 2011, 04:18:03 PM »
Which is better? Positive pcb or negative? I'm using the toner transfer method
Re: PCB:positive vs negative
« Reply #1 on: October 27, 2011, 11:28:10 PM »
The question of using positive or negative photo resist (not PCB) is not an actual option when you use toner transfer, as you just need a thoroughly cleaned copper laminate.
Photo resist is used when you make PCB's with a film and UV light and while negative resist can be hard to come by for the hobbyist, it has a clear advantage over the positive types, as it's easier to avoid pinholes and hairline cracks in the traces.
