Author Topic: need help!  (Read 536 times)
Offline aciq kamarielTopic starter
need help!
« on: October 29, 2011, 12:14:09 AM »
can someone help me on how to programming a servo motor using PIC16F8452 in micro C software.
  • Helpful? 86
Re: need help!
« Reply #1 on: October 29, 2011, 07:17:47 AM »
There are a number of good projects on the web with code on driving a Hobby servo with a PIC.
Google "PIC servo:, "PIC servo controller",  ""PIC servo controller project", "PIC servo controller tutorial" to find them.
Her is one that uses an 18F PIC and is written in C.
http://www.instructables.com/id/Use-a-PIC-Microcontroller-to-Control-a-Hobby-Servo/
However, most are in assembler and for a different PIC but the technique is the same. You will need to learn enough PIC assembler (see data sheet for assembler Instruction Set) to port the code to C and you will also need to learn the details of the PIC you are using, the PIC16F8452, to properly setup the PIC.
A good starting point for learning how to use and program PICs is here:
http://www.gooligum.com.au/tutorials.html
