Author Topic: Fast linear solenoid/piston/actuator  (Read 812 times)
Offline eiritsuTopic starter
« on: November 22, 2011, 09:11:09 PM »
I am looking for a way to make a linear solenoid/piston that moves fast.
As fast as a solenoid would normally move.
The purpose for it is to make my robot's eyelids blink.
So you can imagine, it needs to be fast, like a flicking motion.
I already have the robot face and eyelids so there is a definite amount of space for the solenoid.
I'm currently using a 6mm stroke mini solenoid but the eye lids needs to move 1 inch upwards and downwards.
I'll post pictures of what I build shortly, I'm on my mobile right now.
If possible, I need a solenoid that has a stroke of at least 1 inch.
Where can I buy one which isn't as big as my hand? It's got to fit behind the eye of my robot which is about normal human size.
Re: Fast linear solenoid/piston/actuator
« Reply #1 on: November 22, 2011, 09:34:50 PM »
Normal eyelids aren't 1".
The average eye ball is a little less than an inch in diameter - closer to 24mm, and the eye lid doesn't cover the full diameter.
Even if it did, your 6mm solenoid may be quite fine, if it's strong enough (but with a balanced mechanical setup it should be), as you can just "lever it up".
Like this:
S--o--------E
Where S is the solenoid "attack point", o is the pivot point and E is where the eyelid goes.
I'm not sure what you mean by "a definite amount of space for the solenoid", as this will always be the case ???
Last post September 18, 2008, 08:14:59 AM
Last post April 08, 2010, 05:30:16 AM
by vamsilakshya
Last post August 22, 2011, 03:58:39 PM
Last post November 25, 2011, 09:41:46 PM
by meidou
