Author Topic: help needed  (Read 374 times)
Offline darrenwongTopic starter
help needed
« on: November 22, 2011, 09:40:57 PM »
anyone knows how to calculate the angle of kondo servo motor??
i am using serial manager.
example 7500 = 90degree then 6000 = ?? (the formula) :) :) :) :)
Offline ruben301088
Re: help needed
« Reply #1 on: November 24, 2011, 05:38:45 AM »
if 7500 = 90 degrees, then you can calculate the rest through simple equation.
1 = (90 degrees / 7500)
7500/90 = 1 degree
you can use these two values and multiply as you see fit. This, ofcourse, depends on whether the values of the kondo are scalable or not... I dont know if they are. Just putting the math out there ;)
is that what you wanted?
« Last Edit: November 24, 2011, 05:43:00 AM by ruben301088 »
