Author Topic: Voice Controlled Robot...limited servo movement?  (Read 582 times)
Offline michealcollinsTopic starter
« on: December 02, 2011, 02:11:49 PM »
In your instructible video, you get yours to turn 90 degrees left twice, turning it a total of 180 degrees or so. Then the 'right' command turns it right about 90 degrees. When it's instructed to move forward, it moves a good 2-3 feet.
Mine does not do this. I was so excited to get it working, that I didnt realize that it only turns about 90 degrees, then the servo does not move any further, unless told to move the opposite direction. Then when instructed to move forward, it only moves about 6 inches.
The servos you instructed us to purchase were the HS-311 analog servo for $8.99 a piece. But are you using a different servo in the video? Maybe the continuous that's an extra $20 a servo? Yours do not seem to be restricted to only 90 degrees movements...
« Last Edit: December 02, 2011, 02:55:21 PM by michealcollins »
Offline Gertlex
  • Helpful? 23
Re: For Admin: Voice Controlled Robot...limited servo movement?
« Reply #1 on: December 02, 2011, 02:41:42 PM »
So you're using servos that are not modified as "wheels"?  You need to modify the servos (lots of tutorials for these... it's easy and you'll better understand how servos work, as well).  Don't pay for modified servos, either.
Also please don't use "For Admin" in the title of threads. He already reads everything and doesn't need more ego inflation ;)
I
« Reply #2 on: December 02, 2011, 02:55:07 PM »
Awesome! I didnt know you had to modify them. I'm just following the instructible step-by-step.
Offline Gertlex
  • Helpful? 23
Re: Voice Controlled Robot...limited servo movement?
« Reply #3 on: December 02, 2011, 03:01:10 PM »
Indeed. He's probably so used to taking that step for granted :)
I
« Reply #4 on: December 02, 2011, 03:16:16 PM »
Right on. Totally understand. This sucker is due to be presented in class tomorrow, so I was just trying to get some last minute info. I think it's functionality is good for now. But afterwards, I'm totally taking those servos apart  ;D
Offline Gertlex
  • Helpful? 23
« Reply #5 on: December 02, 2011, 03:24:32 PM »
It's like a 15 minute job. Also tomorrow is Saturday?
I
« Reply #6 on: December 02, 2011, 04:09:30 PM »
yup, Saturday class!
Last post July 15, 2007, 07:20:43 PM
by airman00
Last post October 04, 2011, 10:42:48 AM
by angad
Last post September 19, 2011, 09:03:50 PM
by Gertlex
Last post December 19, 2011, 08:23:32 PM
