Author Topic: hold_servo.hex for Axon (atmega640)  (Read 498 times)
Offline ENG_SKJTopic starter
« on: December 03, 2011, 11:32:57 PM »
I bought an Axon recently. Trying to modify the servos (HS-311) that I have. The link for the software (hold_servo.hex), to command the servo to 0 position, is for Atmaga8. Where can find the .hex for Atmega640 (Axon)? thanks!
Re: hold_servo.hex for Axon (atmega640)
« Reply #1 on: December 04, 2011, 09:26:03 AM »
The hold servo code just does one thing, it tells the servo to go to 0 degrees.
It requires just one line of code:
servo.setSpeed(0);
I compiled it for you and attached the .hex for you. Connect your servo to pin H5, and the servo should stay at angle 0.
ps - if you are using the bootloader, change the file name so that it has less than 9 characters before uploading
Last post August 12, 2008, 01:20:02 AM
by vidam
Last post December 09, 2008, 02:01:29 PM
by pomprocker
Last post March 15, 2009, 03:14:00 PM
by dellagd
Last post May 29, 2009, 09:44:35 PM
by sonictj
