Author Topic: Robotic Arm Design  (Read 1143 times)
Offline Evan3846Topic starter
Robotic Arm Design
« on: December 05, 2011, 10:56:30 AM »
Hello All,
I'm a student and am in the process of designing a robotic arm for a research company. I am planning on using the Axon II MCU but am having difficulty finding motors. The arm needs to have 3 DOFs and the main 'shoulder' joint motor needs to have a torque of around 10Nm. The only problem is that it needs to be able to hold the position for around 30 seconds, so my question is what would be better servos or stepper motors and have you got any reccomendations on what ones to use?
Many Thanks,
Evan
Re: Robotic Arm Design
« Reply #1 on: December 05, 2011, 12:44:36 PM »
[...] the main 'shoulder' joint motor needs to have a torque of around 10Nm. The only problem is that it needs to be able to hold the position for around 30 seconds, so my question is what would be better servos or stepper motors and have you got any reccomendations on what ones to use?
You're not talking about R/C servos (hobby servos) I hope?
10Nm equals ~102 kgf-cm or ~1416 ozf-in.
I'd rather do it with a DC motor, sufficiently geared down of course.
How fast should it move?
« Reply #2 on: December 06, 2011, 04:51:07 AM »
The servo I was looking at was http://www.robotshop.com/ProductInfo.aspx?pc=RB-Ins-01 which could do 11.3Nm. The arm doesn't have to move fast at all, it just needs to be able to hold that weight.
Many Thanks
« Reply #3 on: December 06, 2011, 09:39:29 AM »
OK, that's not a typical servo - extremely slow (90° in 1.5 seconds or the equivalent of 10 RPM) and outrageously expensive at $290  :(
Unless you have someone paying the bills, perhaps you might wanna consider something like this motor at less than a third ($90 to be specific) and with a speed of 720 RPM, which equates to 90° in ~20.8ms (although this is the running speed, it will be a little slower in start-stop conditions). The torque is higher as well.
« Reply #4 on: December 06, 2011, 10:16:28 AM »
Ah yes I did think it was a tad expensive and bulky. That motor looks perfect for the job!  :)
Thank you very much for the advice
Online Admin
« Reply #5 on: December 07, 2011, 08:26:18 PM »
90° in 1.5 seconds for the lifting base section of a robot arm isn't slow :P
Anyway, before you decide what is cheaper, make sure you price out a quadrature encoder + motor driver for that motor. ;D
Last post March 21, 2008, 08:02:02 AM
by airman00
Last post February 22, 2011, 07:59:48 AM
by waltr
Last post July 05, 2011, 12:08:46 AM
by rbtying
Last post April 04, 2012, 07:21:09 AM
by jkerns
