Author Topic: Axon + WebbotLib Button  (Read 442 times)
Offline wecool44Topic starter
« on: December 05, 2011, 06:22:23 PM »
I just installed Webbotlib for use with my axon, and I need the code for the hardware button. Any help would be appreciated.
Offline Gertlex
  • Helpful? 23
Re: Axon + WebbotLib Button
« Reply #1 on: December 05, 2011, 07:12:02 PM »
Install Project Designer, too :)  You can then drag and drop the button into the project, and generate the default project/code, which will have an example code snippet in it.
Webbotlib without Project Designer is pretty much not supported, or recommended :)
I
  • Helpful? 107
« Reply #2 on: December 09, 2011, 02:17:56 PM »
It is supported - but because Project Designer sorts out most of the fundamental problems in initializing your code then its more 'Why wouldnt you use it?'.
Last post January 09, 2009, 11:47:06 AM
Last post January 28, 2009, 07:31:17 PM
by Jdog
Last post April 21, 2010, 04:29:59 AM
by richiereynolds
Last post April 27, 2011, 05:19:28 PM
by tzankoff
