Author Topic: Waterproofing and sealing a robot  (Read 712 times)
Offline NGuggemosTopic starter
« on: December 12, 2011, 09:10:40 PM »
What's up SOR! I have a question on how to seal my robot, so that no air or water can penetrate it's frame. On each side of the frame in my design, there are holes for the axles to penetrate through my frame wall. I have pillow block bearings holding the axle (one on the inside of the frame, and one on the outside, if you have any better suggestions about doing this, let me know) Any suggestions for sealing or waterproofing my robot would make me very happy! I am a bit of a beginner, so I might need basic terminology on complicated suggestions.
Offline Sylvestre
  • Helpful? 12
Re: Waterproofing and sealing a robot
« Reply #1 on: December 12, 2011, 10:21:32 PM »
« Reply #2 on: December 13, 2011, 07:58:26 AM »
Waterproof to what depth? What kind of robot?
Basic questions :P
« Reply #3 on: December 13, 2011, 12:07:36 PM »
A search and rescue robot made out of aluminum and has treads. About a foot of water.
  • Helpful? 84
« Reply #4 on: December 13, 2011, 06:18:42 PM »
The axes could be sealed with hydraulic seals. Some of these could hold to 5000 psi.
http://www.google.com/search?q=hydraulic+seals&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Offline Sylvestre
  • Helpful? 12
« Reply #5 on: December 13, 2011, 07:22:36 PM »
Also, you could try silicone rubber sealant like this in the picture http://www.amazon.com/08641-Corning-Silicone-Sealant-10-1-Ounce/dp/B000BD0QAK/ref=lh_ni_t
« Reply #6 on: December 13, 2011, 08:08:56 PM »
ok thanks, I'll check those out.
« Reply #7 on: December 13, 2011, 09:48:41 PM »
Your electronics should be kept in tube-shaped containers. Box shapes are susceptible to water leaking in.
Use transparent tubes so you can easily check for leaks. Use waterproof wire connectors coming out of the tube containers.
Last post February 10, 2009, 01:03:54 PM
by Joesavage1
Last post March 26, 2009, 12:50:23 AM
Last post April 10, 2009, 01:05:50 AM
Last post January 05, 2013, 10:56:24 PM
by Mastermime
