Author Topic: Axon LED code  (Read 474 times)
Offline wecool44Topic starter
Axon LED code
« on: December 13, 2011, 08:39:52 PM »
I just made an attachment for my Axon that allows it to be connected to a breadboard. I wanted to program it in AVR-GCC(No additional libraries) and the program built correctly. I uploaded it to the Axon, and nothing happens. This code is meant to flash an LED connected to C0. And yes, I did put a resistor before the LED. Here is the code:
#define F_CPU 16000000UL
#include <avr/io.h>
#include <util/delay.h>
main() {
DDRC = 0b10000000;
while(1) {
PORTC = 0b10000000;
_delay_ms(50);
PORTC = 0b00000000;
_delay_ms(50);
Re: Axon LED code
« Reply #1 on: December 13, 2011, 08:51:19 PM »
Just in case, do you have the LED pointing the right direction?
Also, increase the delay to 500. You have it faster than the eye can see :P
Re: Axon LED code
« Reply #2 on: December 13, 2011, 09:00:39 PM »
I tried that, and still nothing happened. I also tried switching the LED's direction, and that didn't do anything. Attached is a picture of the board
Re: Axon LED code
« Reply #3 on: December 13, 2011, 09:36:03 PM »
I noticed your code is changing the bit for C7, not C0 :P
Bits are ordered as DDRC = 0b76543210;
Try this code below. It'll make keeping track of bits easier.
#include <avr/io.h>
//define port functions; example: PORT_ON( PORTD, 6);
#define PORT_ON( port_letter, number ) port_letter |= (1<<number)
#define PORT_OFF( port_letter, number ) port_letter &= ~(1<<number)
DDRC = 0b11111111;  //configure ports for output
main()
  while(1)
    PORT_ON(PORTC,7);
    _delay_ms(500);
    PORT_OFF(PORTC,7);
    _delay_ms(500);
In the end, you're going to find yourself writing your own libraries as your code gets more complicated. It's best to just give in and use WebbotLib :P
Last post February 09, 2009, 09:17:11 PM
Last post June 11, 2010, 02:24:51 PM
Last post October 08, 2010, 12:39:00 PM
by Webbot
Last post February 18, 2012, 09:33:13 AM
by Gertlex
