Author Topic: avr studio - gcc pugin error  (Read 2716 times)
Offline likhinTopic starter
« on: December 16, 2011, 09:41:45 AM »
I get the following error when I click on 'Build' or 'Build All' :
gcc plug-in: No AVR Toolchain installation found. The AVR GCC plug-in can still be used if you set up your own build tools.
I tried closing the window and starting a fresh project but I get the same error  :(
Re: avr studio - gcc pugin error
« Reply #1 on: December 16, 2011, 10:14:45 AM »
Did you install WinAVR yet?
What program are you trying to compile?
« Reply #2 on: December 16, 2011, 11:40:27 AM »
yeah i did install winavr...  I'm trying the 50$ robot...
also.. I've got another question...
where I live, servo motors aren't available, so can I use dc motors?? if yes, do I need to change the source code?? If not.... well, alas :/
  • Helpful? 107
« Reply #3 on: December 16, 2011, 01:32:21 PM »
Did you install WinAVR before installing AVR Studio?
It may be easiest to uninstall both and then re-install both (WinAVR first).
« Reply #4 on: December 17, 2011, 12:55:36 AM »
A common question . . .
http://www.societyofrobots.com/robot_faq.shtml#servo_motor
To use a motor instead of a servo, you need to buy a motor driver. WebbotLib has code to use motor drivers, so it's easy either way.
« Reply #5 on: December 17, 2011, 06:09:25 AM »
Will an ESC work? I'll have to check if they're available...
Is a tutorial on connecting the ESC??
PS: I tried reinstalling WinAVR... works!!  ;D  Thanks!!
« Reply #6 on: December 18, 2011, 08:12:58 AM »
An ESC is a motor driver that takes servo signals. You plug in ground, power, and the signal on one end, and the two motor wires on the other. The instructions for your ESC will tell you more clearly how to do it. With an ESC, you can treat a motor like a normal modified servo.
Last post November 02, 2008, 11:44:06 AM
by Stragen
Last post November 23, 2009, 04:55:25 AM
by Aligator
Last post December 07, 2009, 07:05:11 AM
by GWER57
Last post June 30, 2010, 04:54:01 PM
by Hawaii00000
