Author Topic: How To Put Two Sprockets on One Driveshaft?  (Read 609 times)
Offline SylvestreTopic starter
  • Helpful? 12
« on: December 18, 2011, 01:05:41 PM »
Hello,
How would I put two sprockets on a motor's driveshaft like the one in the link below? Would I need to extend the axle using some type of adjoiner?  http://www.monsterscooterparts.com/24vo400wamow.html
The reason I want to do this is so I my robot will be fourwheeled drive.  Similar to a skid steers drive system http://tinyurl.com/csjjrla
Before, I thought about doing something similar to the picture below, but then I realized the method above would be better.
What are your guys' thoughts?
  • Helpful? 12
Re: How To Put Two Sprockets on One Driveshaft?
« Reply #1 on: December 21, 2011, 11:26:06 AM »
Could anyone verify my proposed method or does anyone have another suggestion of how I could do this?
Offline garrettg84
  • Helpful? 8
« Reply #2 on: December 23, 2011, 03:05:32 PM »
I don't see a problem with your drawing. The only suggestion I could think of is adding a tensioner sprocket/pulley to your existing design. It would allow more teeth of your top sprocket to stay in contact with the chain (less chance for slippage), and also allow for a possible suspension system for your axles. Not to mention a tensioner also allows for easy removal/service to the system.
-garrett
  • Helpful? 12
« Reply #3 on: December 23, 2011, 04:07:01 PM »
Ok thanks for the reply!  I'll do just that.
Last post April 17, 2007, 04:48:37 PM
by Brandon121233
Last post March 14, 2012, 09:16:48 PM
by Mastermime
Last post September 20, 2012, 10:37:16 PM
by fridgid
