Author Topic: DC motor magnet problem  (Read 437 times)
Offline koolraj09Topic starter
« on: December 18, 2011, 03:47:41 PM »
Hi all.
I have this DC motor used for e-bikes [Check here]
I am building a middleweight (<60Kgs) combat robot gearing down the motor from 3300 rpm to 330 rpm via chain drive. I tested it but it's magnets are coming off the casing. I am trying to find the cause of this rip off. I suspect it could be the glue strength, the sudden cyclic reversing of polarity or the rapid acceleration & deceleration . But I need your views. Also is there a way to glue back the magnets? Thanks.
Re: DC motor magnet problem
« Reply #1 on: December 18, 2011, 04:54:55 PM »
[Check here]
Please check your links before posting (preview button, then right click the link and open in new window/tab) - or just copy-paste the raw URL, if you have trouble getting the link option to work.
« Reply #3 on: December 19, 2011, 08:16:02 AM »
It seems easy enough to open, so repair should be possible if you can find a high temperature epoxy or similar, but why not contact the seller and ask for a refund first - motors are not supposed to shed their magnets with normal use - did you drop in on a hard surface?
Last post August 04, 2010, 10:33:36 AM
by ballbreaker
Last post March 13, 2011, 04:53:26 AM
by vinniewryan
Last post April 04, 2011, 11:38:23 PM
by TrickyNekro
Last post August 29, 2012, 04:43:30 PM
by Gertlex
