Author Topic: quadcopter build  (Read 1308 times)
Offline roboninja93Topic starter
quadcopter build
« on: December 20, 2011, 07:50:33 AM »
is it possible to make a quadcopter using brushed motors and motor drivers??
usually brushless motors with esc are used so is it practical using motor driver with brushed motor?
thanks
Offline rbtying
  • Helpful? 31
Re: quadcopter build
« Reply #1 on: December 20, 2011, 01:13:15 PM »
Brushed motors, at reasonable cost points, tend to produce less power per weight than brushless motors; as the motors (via the propellers) provide the entirety of the lift for a quadcopter, it is generally more cost effective to go brushless, especially considering the low cost of brushless motors and ESCs.
« Reply #2 on: December 21, 2011, 12:35:09 AM »
Thanks for the reply...i am on my first quadcopter project and want to spend cautiously... i have brushed motors 12V of 20000+ rpm and draws current of 5 to 6 amp(measured it by a multimeter by connecting d motor with propeller to an eliminator) and can manage the motor drivers... i plan to use avr atmega 8 to control the drivers... so is it practical so go ahead with this or brushless motors are necessary?
i have another question
how do we calculate the thrust produced by the propeller given diameter of the prop?
Offline rbtying
  • Helpful? 31
« Reply #3 on: December 21, 2011, 02:58:06 PM »
The key factor here is thrust-to-weight: how heavy are your motors?
And thrust can be theoretically calculated by looking at the air displaced, but it's easier just to get a prop and measure the force (using a scale or anything like that)
Offline garrettg84
  • Helpful? 8
« Reply #4 on: December 23, 2011, 02:58:50 PM »
Another thought on the brushed motors - the brushes wear out. They also tend to generate more heat. Brushless motors really are designed for this kind of continuous movement.
-garrett
Last post September 28, 2007, 01:07:34 PM
by h3ro
Last post October 19, 2009, 05:02:32 AM
by Joker94
Last post June 01, 2010, 04:32:51 AM
by innerbreed
Last post May 09, 2011, 11:44:54 AM
by Canabots
