Author Topic: The 50$ robot micro-controller.  (Read 472 times)
Offline Silver_79Topic starter
« on: December 21, 2011, 02:36:50 PM »
      I have tried to get the 50$ robot micro-controller to work now for weeks I can't get past the point where both UI's (Linux & Windows 64 bit) tell me the lil piece of crap can't connect to program. It passes the smoke test fine and AVR Studios 5 reads the 5.1V but no device ID. The one I built, like in the tutorial, and the breadboard version I made both do this. I am using the avrispmkII and it says 2 green lights are go lets do this. Then when I try to upload anything or tell the programmer to read the device it fails or when I tell it to read fuses and such it fails. The only thing it does is sets the ISP freq. to 250 kHz and read the voltage level. I so like hardware oriented CPU's like the 6800 family processors. What happened to those and why do we have these pieces of crap that can't do anything without me being a C programmer ? Ok, ok so I am a little bit tired, does the 328p need a separate boot loader when used on the 50$ micro-controller since there is no ext oscillator ?  I am going to breadboard a diff chip up and see if I can get one to do anything but sit there and mock me.
Take Care,
Don
I shall be telling this with a sigh
Somewhere ages and ages hence:
Two roads diverged in a wood, and I–
I took the one less traveled by,
And that has made all the difference.
-Robert Lee Frost-
Offline Gertlex
  • Helpful? 23
Re: The 50$ robot micro-controller.
« Reply #1 on: December 21, 2011, 05:47:04 PM »
Have  you tried AVR Studio 4? I want to say I've heard this to be a problem in the past (using v5, I mean), but couldn't find such a thread just now.
-Gert
I
« Reply #2 on: December 21, 2011, 07:26:57 PM »
      Yeah I tried AVR Studios 4 twice , 5 twice also tried Linux's avrdude and Audrino suite software with no luck.
-Robert Lee Frost-
Offline adanvasco
  • Helpful? 6
« Reply #3 on: December 26, 2011, 07:08:51 PM »
You should double check all your connections and solder points as well.
Knowledge does not weigh.
  • Helpful? 107
« Reply #4 on: December 27, 2011, 12:19:37 PM »
Try reducing the speed of the AVRISP MKII. Seem to remember that its max speed is about one eighth of the CPU speed. For the $50 robot the default clock speed is 1MHz. So try dropping the ISP fequency down.
Nope, you can still use the AVRISP.
Last post July 08, 2007, 08:20:03 AM
by robotvisionary
Last post November 30, 2007, 05:19:19 PM
Last post September 16, 2009, 03:23:12 PM
by ArcMan
Last post August 01, 2010, 10:57:12 AM
by Bas_E
