Author Topic: Lab Power Supply for Axon II  (Read 795 times)
Offline PianigroTopic starter
« on: December 27, 2011, 04:01:47 AM »
Currently I am using a 6V 1.3AH batter to power my Axon robot, however while programming the axon I could do with a lab power supply, so I purchased a AC adaptor power supply (input 100-240V ~ 50/60Hz, Output 6V 1.5A). When I connect to my Axon II, it turns on the off, on then off. The output voltage of the power supply is constant, however the amps oscillate from 1.2 to 0 - not sure why. Has anyone had this problem and can I rig a capacitor or something to stabilise my power supply?
Thanks Paolo
Offline Cristi_Neagu
Re: Lab Power Supply for Axon II
« Reply #1 on: December 27, 2011, 04:23:07 AM »
Sounds like there's a short somewhere. And did you measure the voltage yourself, or does it have an indicator of some sort?
« Reply #2 on: December 27, 2011, 04:30:35 AM »
I measured the voltage myself, I have had similar issued with smaller power supplies (ones used to charge mobile phones), just thought I needed one with more amps. The thing I can not understand is the oscillations. It is unregulated, would the output volts remain constant and the amps vary?
Offline Gertlex
  • Helpful? 23
« Reply #3 on: December 27, 2011, 10:01:09 AM »
What happens if you wire it to a breadboard and an LED+resistor?
I
« Reply #4 on: December 27, 2011, 08:23:27 PM »
What you have is current over draw.
While your battery can likely supply 8A to 16A, your power supply can only do 1.5A. If you draw more than that, the voltage will drop, causing your microcontroller to shut down. When your mcu is down, current drops so voltage is restored, causing your mcu to turn back on again. This causes the oscillation you see.
A single HS-311 servo can draw 1.5A under high torque. Are you powering a servo?
« Reply #5 on: December 28, 2011, 01:40:35 AM »
[...] AC adaptor power supply (input 100-240V ~ 50/60Hz, Output 6V 1.5A).
That's a switch mode supply.
[---] can I rig a capacitor or something to stabilise my power supply?
You could try a small value resistor (5..10 Ohm max) and a cap of 1000µF to 4700µF. This would buffer the peak currents that probably cause supply brown-outs as is.
« Reply #6 on: December 29, 2011, 05:24:25 PM »
Thanks for all the comments, sounds like I am drawing too much power, I am powering 14 servos.
I have looked at other posts on power supplies and may look at converting a PC power supply I have lying around in my garage.
Paolo
Last post February 11, 2009, 08:04:44 PM
by Jdog
Last post June 20, 2009, 06:37:29 AM
by hendrachubby
Last post August 13, 2009, 10:47:09 AM
Last post June 23, 2011, 11:52:14 AM
