Author Topic: need help with webbot lib downloader. to program my new axon 1 mcu  (Read 736 times)
Offline mr robotoTopic starter
hi guys having a problem.
i tried to open the webbot lib project downloader.
for programing my new axon. (YAAAAAY)
but when i go to open it it just opens as a microsoft note pad with gibberish in it.
there is hundereds of lines.
it all looks like this.
sdgwbi/ webbot/ s;\ngobfndjvnjavabdfhwbg/wtf/ilikecheesefwGWjo
b
    dfkh[oefa
 fhdfh[kgj-o
hprkjityjnpfjbpkdfjhplkhbpjgdnmpzkxnb\psjhpfjf//rfb/dg/df/vzxcvsfah//fa/gjhf/syfg/v/xv fhb/
zx/RH/BFs
?BAR
/JRTA
YOU GET THE IDEA. SOMEBODY HELP >:(
« Last Edit: January 01, 2012, 01:31:31 PM by mr roboto »
I once though that my brain was the most wonderful part of my body. then i realized who was telling me this
"A question that sometimes drives me hazy, am i or are the others crazy"?
 Albert Einstein
  • Helpful? 107
Re: need help with webbot lib downloader. to program my new axon 1 mcu
« Reply #1 on: December 30, 2011, 10:36:25 AM »
I think whats happening is that you don't have a copy of Java installed. So instead of executing the java program its just opening it like a text file.
You need to download a Java JRE http://www.java.com/en/download/index.jsp
« Reply #2 on: December 30, 2011, 12:07:19 PM »
yeah im trying to.
thank you for bearig with me.
i installed java but when i go to open the downloader it just reinstalls java.
again and again.
sorry for my noobieness.
 Albert Einstein
  • Helpful? 107
« Reply #3 on: December 30, 2011, 12:11:58 PM »
What O/S are you running? Win XP, Win 7, Mac, Unix etc
« Reply #4 on: December 30, 2011, 12:40:50 PM »
windows 7 is what im running at the moment.
 Albert Einstein
  • Helpful? 107
« Reply #5 on: December 31, 2011, 07:47:50 AM »
When you say
I'm not quite sure I understand. Does the downloader window open? What do you see on the screen? Are you sure its downloading Java or is it downloading other stuff (ie WebbotLib stuff)?
« Reply #6 on: December 31, 2011, 01:46:56 PM »
okay so i install java
then i go to open the downloader and it opens the window that downloads java.
i restarted the computer.
but java wont install wright.
 Albert Einstein
« Reply #7 on: December 31, 2011, 08:49:18 PM »
What error are you getting?
  • Helpful? 107
« Reply #8 on: January 01, 2012, 09:59:40 AM »
I'm still slightly confused by the word 'downloader' - ie is it the Java Downloader (when you are installing Java) or is it the Webbot Downloader (for when you are trying to install my bits'n'pieces - which DOESN'T include Java since you've got to have Java installed in order to run it).
So first of all - check that Java itself is installed:-
1. Launch a Command Prompt (ie run 'cmd.exe) and type
java -version2. You should see a response like:
java version "1.6.0_24"
Java(TM) SE Runtime Environment (build 1.6.0_24-b07)
Java HotSpot(TM) 64-Bit Server VM (build 19.1-b02, mixed mode)
If so then java is installed.
3. If you get a message saying it is not recognised then download Java from the web site link I gave you before. NB Sometimes I find it easier to save the downloaded file rather than run it. This makes it easier to re-install if you need to without having to re-download over and over again. Having downloaded the java installer then run it. You may need to be the Administrator of the computer.
4. Unless you succeed with this (ie you get something sensible in point 2 then there is no point in continuing).
Ok so you've now got java. What do you see in the output from point 2 above?#
Now you can download the Webbot Downloader from http://webbot.org.uk/iPoint/48.page.
You should end up with a JAR file - (which is like a Java ZIP file).
You should be able to double click on it to run it.
This will give you a window titled 'Webbot Download' with a list of things that can be downloaded. To activate an entry in the list you double click on the entry and say where you want to download that 'thing' to on your computer. Once set it will then start downloading that item. NB It should never start downloading Java itself since you must already have that installed for Webbot Download to run.
« Reply #9 on: January 01, 2012, 01:31:08 PM »
hi
i got it working. so its solved.
thank you.
i just downloaded the files directally instead of through the downloader.
 Albert Einstein
Last post November 03, 2009, 07:35:14 AM
by Asellith
Last post July 04, 2010, 06:29:21 PM
by KurtEck
Last post October 06, 2010, 09:02:54 AM
by Kelpy
Last post February 17, 2011, 04:28:26 PM
by Webbot
