Author Topic: How do you map with a Sharp IR Rangefinder?  (Read 958 times)
Offline IcyroboticsTopic starter
« on: December 31, 2011, 11:49:48 AM »
Can you please give me a pretty detailed description on how to map with a Sharp IR Rangefinder?
I want to map my room and I can't figure out how to set it up.
                    PS: You can also e-mail me if you want...
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
Re: How do you map with a Sharp IR Rangefinder?
« Reply #1 on: January 01, 2012, 10:52:54 PM »
Hmmm ok, that's like crossing the Atlantic with a canoe. Not impossible, but....
Anyhow, I've seen people using the Xbox Kinect for 3D mapping of rooms, bodies, etc etc etc...
And for what it does, I would say it's rather low cost.
And I also guess that you might be trolling around forums (hope not) so I do provide some kind of answer,
so that others don't only waste time in a forum.
Cheers!
Offline msprague
« Reply #2 on: January 02, 2012, 09:40:51 AM »
These may give you some ideas:
http://www.societyofrobots.com/robot_iRobot_Create_mod.shtml
http://letsmakerobots.com/node/11353
http://letsmakerobots.com/node/2558
After you do some more reading, if you have specific questions feel free to ask.
I hope that helps,
Michael
Offline swordrock
« Reply #3 on: July 23, 2012, 05:28:20 AM »
I am also building a robot which aims to sweep in a room and come up with a map of the enviroment.
I parse a big square matrix, where each member of the empty matrix represents my robot's size. If robot sees any obstacle this member of the matrix will be a 1 (or any other thing says there is an obstacle) . I've tried to create an algorithm by hand but failed.
I have sure seen this project http://www.societyofrobots.com/programming_wavefront.shtml   but there is no explanation about map creation while sweeping in the enviroment with a Sharp Range Finder.
Seems simple so much but actually i am searching for this simple algorithm, and this is the only forum i am asking it.
Thanks in advance for your help.
Offline BradleyK
Last post February 24, 2008, 04:02:06 PM
by javafiend
Last post October 14, 2008, 04:16:34 PM
by airman00
Last post April 07, 2008, 12:13:55 PM
by superchiku
Last post September 01, 2010, 07:25:23 AM
by Andyspins
