Author Topic: [advertisement] New 12V Micro Gearmotors from ServoCity - Just $14.99  (Read 2134 times)
Offline ServoCityTopic starter
  • Helpful? 18
We are proud to introduce our new line of Micro Gearmotors and gearmotor attachments!
ServoCity Micro GearmotorBlocks - Just $14.99!
Although these mirco gearmotors have a footprint comparable to a micro-size servo and tip the scales at only 0.6oz, the are incredibly powerful. All-metal gears ensure the motor will hold up in even the harshest applications. The extremely versatile gearmotor case provides protection for the gears and offers numerous mounting options to fit a variety of custom applications. These micro gearmotors have a 3mm D-shaft that protrudes from the gearbox case. The shaft is compatible with our new line of 3mm bore attachments shown below.
The micro gearmotors are offered in 9 different speeds, ranging from 45 RPM to 4,900 RPM!!
The Gearmotor has a "D" shaped 3mm bore shaft.
Micro Gearmotor shown to scale.
The Micro GearmotorBlocks have (2) #4 thru holes.
4-40 screws are able to pass through the #4 thru holes.
6-32 screws are able to thread into the mounting holes.
Micro GearmotorBlocks can easily bolt together to create gearmotor structures.
We have various attachments available such as the:
3mm bore pinion gear - $12.99
3mm bore lightweight set screw hub - $6.99
For more information or to purchase one of our great little gearmotors, visit:
