Author Topic: can i use  (Read 283 times)
Offline shreyanshTopic starter
can i use
« on: January 07, 2012, 07:12:45 AM »
i m not getting hitec hs-311 servo
can i use simple motor in place of servo
thanks
Offline billhowl
  • Helpful? 32
Re: can i use
« Reply #1 on: January 07, 2012, 11:02:03 AM »
Yes, for $50 robot, if you not using servo, can use simple motor in place of servo but you need to have h-bridge motor driver like L293 to drive the motor and you need to change the software.
Bottom line is the construction will not going any lower cost.
Re: can i use
« Reply #2 on: January 07, 2012, 09:13:13 PM »
... And the motor needs to either be a gear head motor, or have an external gear box.
