Author Topic: Atmega8 Maximum Logic 0 Voltage  (Read 446 times)
Offline adaschau2Topic starter
« on: January 07, 2012, 01:37:58 PM »
Hello again everybody,
     I just encountered a problem with a sensor that may be resolved by the answer to the following question: what is the maximum voltage that will be considered 0 logic on the Atmega8? I know that I should probably be able to find it on the datasheet, but I cannot for the life of me locate it. Here is the sheet if one of you pros wants to point me in the right direction: http://www.atmel.com/dyn/resources/prod_documents/2486S.pdf. Thanks for your help!
P.S. For you curious types, my issue is that I have an IR emitter being cut off from a detector, but I'm only able to lower the signal to about 1.5 volts or so.
Online billhowl
  • Helpful? 32
Re: Atmega8 Maximum Logic 0 Voltage
« Reply #1 on: January 07, 2012, 07:20:41 PM »
maximum voltage for logic 0(Low) is 0.2*Vcc, for 5V supply will be 1V.
The info you can find in this datasheet page 242
http://www.atmel.com/dyn/resources/prod_documents/doc2486.pdf
So for your IR emitter have to lower the signal to about 1 volt.
« Reply #2 on: January 08, 2012, 12:56:50 AM »
Thanks Bill! I actually did skim through that section, but I guess I missed the "I/O Pin Input Threshold Voltage" graphs among the 80 other graphs in that section on the first pass :P.
Last post February 08, 2008, 07:43:25 AM
by Geir
Last post March 24, 2008, 12:23:02 PM
by benji
Last post April 06, 2008, 01:10:17 PM
Last post June 13, 2009, 09:24:14 PM
by awally88
