Author Topic: Software programming trouble.  (Read 2061 times)
Offline robotvisionaryTopic starter
  • Lucky I wasn't that driver.
« on: July 10, 2007, 05:32:59 AM »
Hey I have a Mac OS X computer and i am wondering is it possible to get a typing program for my computer.
An second if i could get one will the microchip still understand the programming or will it burn?
MACHINTOUCH (MAC) RULEZ. WINDOW STINKS.
I've have not failed, I've just found out 2,000 how a light bulb will not work
                              Thomas Edision.
[youtube]59xcT1dstq4[/youtube]
Re: Software programming trouble.
« Reply #1 on: July 11, 2007, 11:17:14 AM »
??? you mean like a text editor? an IDE?
which microchip?
Check out the programming section on my $50 Robot. It might help you understand robot programming better so that you know what questions to ask:
http://www.societyofrobots.com/step_by_step_robot_step4.shtml
« Reply #2 on: July 12, 2007, 06:30:35 AM »
The microchip is the AT mega8
                              Thomas Edision.
Offline rgcustodio
« Reply #3 on: July 12, 2007, 05:47:21 PM »
The source code (this is just text that adheres to the coding semantics of the programming language you are using) you will create can be transfered from different programming environments (Windows, Linux, etc). This code passes through a compiler which produces a binary. This binary is the one that is burned to the MCU. The environment where the binary is created does not matter as long as the compiler used targets the MCU that you are using you are good to go.
The GNU AVR C that is commonly used in developing AVR applications has a Mac port here: http://avr-gcc.darwinports.com/
You might also want to check out avrdude here: http://avrdude.darwinports.com/
Last post August 18, 2007, 10:32:16 AM
Last post February 11, 2008, 06:05:41 PM
by BANE
Last post September 25, 2009, 05:07:27 AM
by toocool
Last post February 26, 2010, 04:35:23 AM
by Finnik
