Author Topic: Any recommendations for a local positioning system?  (Read 688 times)
Offline murrdpirateTopic starter
« on: January 10, 2012, 02:58:30 PM »
I am working on a project that will involve multiple robots carrying heavy items for humans.  I need to develop a system that will accurately monitor the position of each robot (probably to within about 20 cm).  The environment will be known beforehand, but can be quite large (~200 square meters or more).  It will be outdoor and line of sight can easily be maintained.
A few methods I've been going over:
Acoustic trilateration
GPS combined with RF phase difference measurements
Burying a grid of RFID tags and measuring strength of signal
Computer vision triangulation
I'm pretty confident that the computer vision triangulation would work well, but might get expensive.  If anyone has an suggestions, I'd be very grateful.
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
Re: Any recommendations for a local positioning system?
« Reply #1 on: January 11, 2012, 02:40:39 AM »
If paths are known beforehand and they would not change, You can use line follower technique.
« Reply #2 on: January 12, 2012, 08:32:23 AM »
Large? It's just about half the size of an NBA basketball court ;)
Too many ways it can go wrong IMO.
Signal strength is a poor indicator, as it will depend on the depth, the "quality" of the dirt, moisture content, mineral content etc. so will most likely vary from one place to another, even in between two tags and the cheap old RFID's won't carry more than 10..20cm in free air, so when you add dirt, they'll be close to unreadable unless you're close (i.e. right above it).
Better bury a grid of signal carrying wires then - cheaper, easier to layout precisely (although may be a bit more work actually getting into the ground, if you have to do it alone by yourself) and a lot easier to read (which makes the "receiver/reader" cheaper as well).
With the 20cm precision you need, you can use odometry for positioning and correct/reset the measurements each time a wire is passed (X and Y). With 5m between each wire in the grid, your 20 cm tolerance equates to 4% and that should keep the odometry readings well in check.
GPS, with the precision you want, will be expensive as well.
« Reply #3 on: January 18, 2012, 06:24:22 PM »
Oops, meant to say 200x200 meters!  I appreciate the feedback.  Any thoughts on the vision triangulation?
Offline Chewy
« Reply #4 on: January 20, 2012, 01:21:13 PM »
Hi Murrdpirate,
  For vision triangulation, consider Fiducial detection using RoboRealm (see http://www.roborealm.com/help/Fiducial.php).  Quite easy to use and with a higher resolution camera should be capable of meeting your 20 cm precision requirement.
  Also, consider using GotABot (see http://gotabot.weebly.com/) as an additional aid.  It can provide mapping, path planning, localization and other capabilities for your application.
    Cheers
Last post November 17, 2007, 06:58:14 PM
by paulstreats
Last post February 16, 2008, 04:57:03 PM
Last post December 16, 2011, 06:14:30 AM
by SP
Last post December 10, 2011, 01:24:15 AM
by eextreme
