Author Topic: $50 robot motor  (Read 395 times)
Offline shreyanshTopic starter
$50 robot motor
« on: January 12, 2012, 08:53:45 AM »
if i m using simple motor in $50 robot inplace of HS-311 servo i need to change the software or not
thanks
Offline altapowderdog
Re: $50 robot motor
« Reply #1 on: January 12, 2012, 03:31:19 PM »
if you use a speed controller to drive your motors that accepts servo inputs such as a sabertooth like this, then you should not need to alter your code.  The speed controller connects just like a servo, and drives your motors in the same way that a servo modified for 360 rotation would rotate.
http://www.robotmarketplace.com/products/0-SABER2X5-RC.html
Im not sure if this is what you are asking- but I hope that helps.  You will need another power supply to power a speed controller.  For motors I would check out the solorbotics gm9 motors:
http://www.solarbotics.com/products/gm9/
A combination of two of those motors and a speed controller will behave exactly like servos modified for continuous rotation.
Last post September 05, 2007, 07:12:24 AM
Last post February 04, 2009, 12:29:06 PM
by horo333
Last post August 20, 2009, 02:34:27 PM
by SmAsH
Last post December 10, 2009, 03:38:03 PM
by definitionofis
