Author Topic: Using a Joystick to Control a Robot  (Read 1295 times)
Offline SylvestreTopic starter
  • Helpful? 12
« on: January 14, 2012, 06:25:15 PM »
Hey everyone,
I am thinking of using a joystick such as one in the link below to control my rescue robot.  If I used this, I would just have it connected (Usb obviously) to the laptop I'm controlling the robot from.
How difficult would it be to program something like this?  Would someone who has done this before care to share some example code? (preferably in C)
http://www.amazon.com/Logitech-Extreme-Joystick-Silver-Black/dp/B00009OY9U/ref=sr_1_4?ie=UTF8&qid=1326586764&sr=8-4
« Last Edit: January 14, 2012, 07:42:51 PM by Sylvestre »
Offline Redcap
  • Helpful? 11
Re: Using a Joystick to Control a Robot
« Reply #1 on: January 15, 2012, 08:53:57 PM »
I'll be the first to admit I don't know a great deal about joysticks, but to get the replies started...
Most joysticks I've seen have a setup interface where you can define which each movement/button press should be such as tilt to the left = left arrow, "fire" button = spacebar etc.
I'm only assuming, but from there it may just be a case of having the code look for a press of the left arrow key, which (I assume) would also see the Joystick being tilted to the left as this key being pressed. etc
Hopefully someone with more experience with this comes along very soon to enlighten us both ;)
  • Helpful? 12
« Reply #2 on: February 12, 2012, 12:13:33 AM »
ok thanks for the information!  Yeah hopefully helps us out.
Offline Daanii
« Reply #3 on: February 16, 2012, 12:47:15 AM »
What operating system are you using? If you use Windows, the thing I use is DirectInput. You can then get a value from the various axes and buttons on the joystick.
How will you send signals to your robot from the laptop?
I have some code that might be helpful, if you are using Windows.
Offline Resilient
« Reply #4 on: February 16, 2012, 02:15:55 AM »
If you want something cross platform check out SDL
http://www.libsdl.org/
  • Helpful? 12
« Reply #5 on: August 26, 2012, 11:38:15 PM »
I need to revisit this topic.  Sorry for my delayed response.  Now to the answers of your questions.
I am using Windows.
Serial communication.
I'll check out both SDL and DirectInput.  Thanks for the response
« Last Edit: August 26, 2012, 11:39:52 PM by Sylvestre »
Last post March 18, 2009, 08:22:27 AM
by offy
Last post February 05, 2011, 10:24:55 AM
by BANE
Last post March 29, 2011, 06:50:33 AM
by rbtying
Last post March 19, 2013, 03:05:50 AM
by cnd
