Author Topic: How to make Robot sensitive to direction....  (Read 492 times)
Offline RITESH29Topic starter
« on: January 18, 2012, 07:08:02 AM »
Offline newInRobotics
  • Helpful? 46
  • N.I.R.
Re: How to make Robot sensitive to direction....
« Reply #1 on: January 18, 2012, 08:08:50 AM »
Hi there
Gyro will not show direction as it outputs angular velocity detected around axis. You can use it, but it will difficult and not very precise.
Accelerometer is useful only when robot is moving, otherwise it will output 1G along vertical axis. If Your robot does not use omniwheels, accelerometer can be used to determine if robot is going backward or forward and angle of the turn when it's turning (not applicable for differential drive bots). If robot uses omniwheels and does not rotate around any axis, 2 axis accelerometer will indicate movement in 2D plane and You will be able to know which direction it is heading to.
To know absolute direction of movement of a robot which has front and back (like a car) and does not go sideways - compass is the way to go.
« Reply #2 on: January 18, 2012, 08:11:07 AM »
HI,
I want to make a bot called automatic which will move with help of Encoder and Line follower it has to rotate also in 90* so, i was thinking to use it!!!
  • Helpful? 46
  • N.I.R.
« Reply #3 on: January 18, 2012, 08:37:03 AM »
Using gyro or accelerometer will be difficult to get robot to turn exact amount of degrees. With compass it will be very easy.
currentAngle = getCurrentAngle(); //relative to north
turnCW(motor1);
turnCCW(motor2);
while (getCurrentAngle() != curentAngle -/+ 90) //modular arithmetics will be required
{} //do nothing
stopMotor(motor1);
stopMotor(motor2);
Something like that.
Last post February 03, 2009, 04:16:06 PM
by Razor Concepts
Last post February 24, 2010, 06:34:32 PM
by richiereynolds
Last post August 10, 2012, 04:06:10 PM
Last post October 26, 2012, 10:54:04 PM
by napnyl
