Author Topic: Phototransistor vs. Photodiode  (Read 3962 times)
Offline pterrusTopic starter
« on: January 23, 2012, 12:21:05 PM »
I bought an IR emitter/detector from radioshack and built the basic circuit shown here.  However the circuit didn't work as I expected at all.  The voltage across the detector seemed to be 0.7 V no matter what I did, although I did notice a really subtle change in resistance if pointed at the emitter.
Then I read the reviews here and it seems that some of these packages are mislabeled, and I may actually have a photodiode, not a phototransistor.  That would seem to explain a lot.
My question is: what exactly is the difference?  Can a photodiode work just as well as a phototransistor for a line following robot?  If so, can someone recommend a circuit?  Or should I just return the mislabeled diodes?  Thanks for the help.  :)
Offline Billy
Re: Phototransistor vs. Photodiode
« Reply #1 on: January 23, 2012, 02:29:28 PM »
If you did get a diode instead of a transistor, and it always reads 0.7V, try turning the diode around to reverse the bias.
« Reply #2 on: January 23, 2012, 03:46:49 PM »
Did you successfully identify the IR-LED of each pair?
A photo transistor is a transistor with a photo/light sensitive basis. Like a regular transistor with a photodiode on the basis
Not in the "Infrared Emitter Detector Basic Circuit".
If you decide to go with an op-amp per detector, it can be coupled to work.
Your call, whether you'll let the Shack get away with it (they won't change their ways unless enough people demand the right parts).
If you decide to keep them AND use an op-amp per detector, let us know.
