Author Topic: Help with component selection  (Read 428 times)
Offline tuxgeekTopic starter
« on: January 24, 2012, 04:31:22 PM »
Hello all. I am looking at building a robot for a capstone project in a computer information systems class I am in. I am wanting to build something tracked that has a pan/tilt platform on top and I already have plans for the way I am going to build the tracks, I know what microcontroller platform I want to use, but the rest of it, I need help picking out parts for. The biggest issue is that I need to be fairly low budget. I want to start with a smaller version, which I see as a 8 inches to 1 foot long so I can use that to see if anyone I know would be willing to contribute financially towards the full size version.
1.   Motors - I can’t really get a feeling for how much power something has by just looking at ratings, so I have no clue what to even start to look at.
2.   Batteries - I need something with decent bang for the buck, without being too big or heavy for the rest of the thing. I like lead-acid because of the cheap factor, but would cheap cordless tool batteries work?
3.   Motor controllers – I can probably build something, but if there’s one that is affordable, even better
4.   Wireless system -  I plan to make it computer controlled by Bluetooth or WiFi in the end, but for testing, I will need a standard controller
5.   Accessory mount movement – I don’t know what to use to control the pan and tilt movement of the accessory mount.  I figured it would be best to use a servo for the tilt mechanics since it only needs at most 135 degrees of tilt control. The problem is I need it to be able to support a decent sized camcorder. For the rotation, I figured a motor would be the best idea since I need full rotation. I was planning on connecting the motor to the turntable via chain or direct gear and then using a rotary encoder on the turntable to sense where its facing.
If anyone is selling anything that would be useful for this, I would love to know. I have no objections to buying used.
I think I remembered the vast majority of my questions, and I look forward to your experienced answers.
PS - Judging by the number of verifications, i have a feeling that some members like turning their creations free on the website...  :P
Re: Help with component selection
« Reply #1 on: January 24, 2012, 07:17:33 PM »
I just realized that I probably posted this in the wrong section, so if it needs to be moved, please do.
Related to my OP, I found this motor(http://www.allelectronics.com/make-a-store/item/DCM-130/24-VDC-135W-MOTOR-W/BELT-GEAR/1.html), and with enough reduction I think it will work just fine. What do ya'll think?
Offline Gertlex
  • Helpful? 23
« Reply #2 on: January 25, 2012, 12:08:48 AM »
Got nothing on #1.
Ebay for 6V or 7.2V NiMH batteries like those used in RC stuff are probably good for this (and you can always cross check with non-ebay sellers). You'll also need a charger.  I suppose cordless tool batteries would work.
Here's a schematic for a motor driver that will probably suit your needs as long as you don't use crazy powerful motors.  http://forums.trossenrobotics.com/showthread.php?3907-Dual-Gun-motor-driver&highlight=motor  PWM to the 5V input can provide speed control.
What do you mean by standard controller?  Regardless, the approach that'd be best for testing would be a wired connection... Most microcontrollers have such.
One option is to use a 4-bar linkage to keep the weight off the tilt servo (you won't get as wide a tiltl range though).  Multi-turn panning is not something I'd try to do cheaply, I guess... Turn the robot instead (tracks are nice for that...).
You could use a Wifi secuirty camera e.g. Trendnet IP110WN or the smaller, similar D-Link camera.
I
« Reply #3 on: January 25, 2012, 09:54:42 AM »
I kinda meant like a standard wireless controller (like a RC car), but tethering would work
Yeah, I think I will just turn  the bot. It makes it easier to engineer.
Motor wise, I am looking at:
http://www.robotmarketplace.com/products/0-HTIM1.html Its fairly cheap, but I am not really sure of the power output
http://www.robotmarketplace.com/products/0-DTXP5737.html Seems like a nice cheap motor, but it would need insane gears, and again, not sure of the power output
http://www.allelectronics.com/make-a-store/item/DCM-130/24-VDC-135W-MOTOR-W/BELT-GEAR/1.html I still think this would be good, but I need more opinions.
Now that I am looking at the price of the motors, I think I might wanna build it as full size from the start. I plan on it being 18"x9" for the platform with 2" wide tracks. I'm not sure yet. If I can get the motors cheap enough, I can scale up the rest of the components once I have the money. I don't really want to use the materials to have to build 2 frames for it, and it will be cheaper to just buy one set of motors. For most of the motors, I could also start out with one per track, but leave provisions to have 2 per track as an up-scaling method. What do you guys think?
Last post October 10, 2008, 05:17:51 AM
Last post October 17, 2008, 01:34:56 PM
by airman00
Last post March 09, 2010, 06:57:48 AM
by robaker
Last post August 06, 2011, 09:02:27 PM
by corrado33
