Author Topic: trying to decide on a servo  (Read 435 times)
Offline Robotics12Topic starter
« on: January 28, 2012, 01:46:14 AM »
In process of building go kart (wireless) and was needing to know what size steering servo would work? Are there formulas I can use or anyone have a general idea as far as torque, etc I would need for a standard size go kart? The 250-300 oz-in range?
Re: trying to decide on a servo
« Reply #1 on: January 28, 2012, 11:21:32 AM »
Yes, but you cannot use a formula without having numbers to plug in.
You need to measure how much torque is needed - directly where you're going to interface the steering.
If you mount an arm at that place and use a luggage scale, pulling the arm in a known distance from the center of the axle you're turning (and with the pull direction 90°to the arm at all times, you find the torque needed. when that's done, get back with the result.
A drawing on how you're gonna make the mechanical interface would help things along as well.
Last post April 07, 2007, 08:31:17 AM
by sotu
Last post December 18, 2011, 03:54:51 PM
by mr roboto
Last post December 30, 2011, 01:57:25 AM
by df143
Last post January 13, 2013, 05:17:58 PM
by jwatte
