Author Topic: build simple robot used transistor  (Read 982 times)
Offline alaterlightTopic starter
« on: January 31, 2012, 03:17:32 AM »
build a simple robot does not use microcontrollers. mainly used transistor. help me
Offline billhowl
  • Helpful? 32
Re: build simple robot used transistor
« Reply #1 on: January 31, 2012, 05:08:34 AM »
Have you find this...
Line follower, obstacle avoider, photovore and photophobe in $40
http://www.societyofrobots.com/member_tutorials/node/59
If you do not want to use L293D motor driver, you can replace it with transistors H-bridge like this
http://www.robotroom.com/BipolarHBridge.html
« Reply #2 on: February 01, 2012, 03:48:52 AM »
no microcontroller use L293D. single transistor used. you can make H-bridge controller is smooth ,but how do other
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
« Reply #3 on: February 01, 2012, 07:14:30 AM »
I'm not sure what You ask, but i will try to guess. Robot that billhowl linked You to does not use microcontroller. L293D is not uC - it is a motor driver, you either use that or use H-bridge consisting of at least 4 transistors.
That won't happen  ;D
Smooth H-bridge driving (or have You meant smooth motor control) requires PWM which in turn requires uC or something like 555 Timer in astable mode and a lot (and I mean A LOT) of hand tuning.
,but how do other
Sorry, do what now?  ;D
NOTE 1: You did not tell us what do You want Your robot to do.
NOTE 2: You would get more replies if Your sentences were constructed better (with more effort say).
« Reply #4 on: February 02, 2012, 02:27:29 AM »
,but how do other
I want to make a simple robot automatically. function to the left, right, up and down. avoid obstacles. using transistor. important not to use microcontrollers. help me  :'(
« Last Edit: February 02, 2012, 02:30:27 AM by alaterlight »
  • Helpful? 45
  • N.I.R.
« Reply #5 on: February 02, 2012, 02:40:49 AM »
Makes much more sense now  ;)
I'll repeat myself: Robot that billhowl linked You to does not use microcontroller and does exactly what You want it to do - avoids obstacles.
help me
What help exactly do You need?
Last post December 21, 2008, 06:33:24 PM
by Ro-Bot-X
Last post October 16, 2008, 09:22:55 PM
Last post February 09, 2009, 05:19:02 AM
by horo333
Last post December 13, 2011, 03:15:22 AM
by fridgid
