Author Topic: Webbotlib and ATMega644: "Device not defined in your makefile"  (Read 1009 times)
Offline mstachoTopic starter
  • Helpful? 10
« on: February 01, 2012, 02:11:36 PM »
Howdy,
Just trying to play around with the '644, and when using webbotlib I get an error that tells me that the device is not defined in my makefile.  This is...odd because the makefile has the lines:
## General Flags
PROJECT = test644
MCU = atmega644
TARGET = test644.elf
CC = avr-gcc.exe
and a number of other references to the atmega644.  I linked the libraries correctly, I think (but I'll check again, I'm open to anything...).  Any thoughts?
MIKE
  • Helpful? 10
Re: Webbotlib and ATMega644: "Device not defined in your makefile"
« Reply #1 on: February 01, 2012, 02:23:27 PM »
Ah, replying to myself.  Fixed the problem, although I have a feeling my fix is not complete.
In the file "device.h" in the webbotlib, the device isn't defined.  I had to add the lines:
   Define common data structures used by the device
#if defined (__AVR_ATmega640__) //DID NOT ADD THIS
# include "dev/ATmega640.h"   //DID NOT ADD THIS
#elif defined(__AVR_ATmega644__) //ADDED THIS!
# include "dev/ATmega644.h" //ADDED THIS!!
etc
Should I also include the UART stuff that is defined for the other chips?
MIKE
