Author Topic: Servos  (Read 360 times)
Offline DaithiSp01Topic starter
Servos
« on: February 01, 2012, 07:08:28 PM »
using servos which have the ability to lift 14kg's, I have sourced a recargable 9v battery will this be powerful enough to operate each servo and run a brushless motor? could I add in a second power source easily?
Re: Servos
« Reply #1 on: February 01, 2012, 08:46:25 PM »
If you by 14kg means they have a torque of 14kgf-cm, they're pretty large - do you have them already?
Nowhere near!
If you mean a PP3 battery (rectangular battery/transistor battery/whatever you call them), you won't even be able to feed one of the servos.
Since I don't know what you're building or your skill level, I can't say how easy you'll find it, but motor and servos runs fine on a "secondary" battery, as long as you keep the ground connected to the existing ground (and the servo signal coming from a micro-controller or similar should not be connected to this battery at all).
Which specific servos and motor (Link)?
Last post April 11, 2006, 10:27:13 AM
Last post October 10, 2008, 05:14:52 AM
Last post January 11, 2009, 09:02:46 PM
by Razor Concepts
Last post April 17, 2009, 06:08:35 AM
by Razor Concepts
