2
Author Topic: Dongle help!!! PLS READ!!  (Read 5384 times)
Offline robotvisionaryTopic starter
  • Lucky I wasn't that driver.
« on: July 11, 2007, 07:50:56 AM »
I Bought this dongle adapter for $40.00. But when i connected to my computer it doesnot show and the light is blinking wish suggest me that it thosnot have enough power. Is this true?
Adapter pic:
http://www.compusa.com.pr/products/product_info.asp?pfp=SEARCH&Ntt=serial+adapter&N=0&Dx=mode+matchall&Nty=1&D=serial+adapter&Pn=USB%5FSerial%5FPortable%5FAdapter&Ntk=All&product_code=309975&Pn=Serial_to_USB_Adapter
Also if it does not work can you tell me of another one. Preferably in compusa or radioshack.
I've have not failed, I've just found out 2,000 how a light bulb will not work
                              Thomas Edision.
[youtube]59xcT1dstq4[/youtube]
Offline KambeiX
Re: Dongle help!!! PLS READ!!
« Reply #1 on: July 11, 2007, 08:30:02 AM »
try to connect it to another computer. It must be an issue of your usb port rather than the adapter itself, but if you can't make it work in another computer, then the adapter could be having problems.
Offline Kohanbash
« Reply #2 on: July 11, 2007, 11:18:08 AM »
Have you installed the drivers/software for it?
Offline Dosbomber
« Reply #3 on: July 11, 2007, 11:04:31 PM »
Are you connecting it to a primary USB port on your system, or a USB port on another USB device, such as a keyboard?  Some of those keyboards with USB ports built in can't provide full power to additional devices.  The Logitech G15, for example.
Dosbomber
« Reply #4 on: July 12, 2007, 06:15:42 AM »
N i am connecting it to the hi speed port in the computer and i have tried at least 5 computers.
                              Thomas Edision.
« Reply #5 on: July 12, 2007, 06:49:27 AM »
What are you connecting to the other end of the adapter?
« Reply #6 on: July 12, 2007, 08:00:35 AM »
the usb
                              Thomas Edision.
« Reply #7 on: July 12, 2007, 08:50:43 AM »
The serial end is connecting to what device?
The usb end is connecting to what device?
You must tell us everything you are doing and have done, or we cannot help you . . .
You haven't even told us how you know it isn't working!
Offline Kohanbash
« Last Edit: July 12, 2007, 11:41:37 AM by sdk32285 »
« Reply #9 on: July 12, 2007, 07:10:30 PM »
THe serial is connected to the $50 dollar robot brain.
The usb is connected to the computer.
I know is not working because
1) is it not showing on the computer.
2) the light on the adapter is blinking.
                              Thomas Edision.
« Reply #10 on: July 12, 2007, 09:35:43 PM »
Dont you mean the programmer? Is the programmer turned on or off?
Did you install the drivers for the adaptor yet (there should be a cd that came with the adaptor)?
« Reply #11 on: July 12, 2007, 10:23:11 PM »
Yes I did all that. I am thinkin on bying this other adaptor. Will it work?
http://www.radioshack.com/product/index.jsp?productId=2036258&cp=&pg=1&sr=1&retainProdsInSession=1&retainProdsInSession=1&y=3&origkw=serial+usb+adapter&kw=serial+usb+adapter&x=14&numProdsPerPage=100&parentPage=search
Or this one.
http://www.compusa.com.pr/products/product_info.asp?pfp=SEARCH&Ntt=serial+usb+adapter&N=0&Dx=mode+matchall&Nty=1&D=serial+usb+adapter&Ntk=All&product_code=289594&Pn=USB_Serial_Portable_Adapter
                              Thomas Edision.
« Reply #12 on: July 13, 2007, 04:43:53 AM »
Those are both waaay overpriced. But yea they should work.
Notice one says "This product is not Windows Vista compatible."
« Reply #13 on: July 13, 2007, 08:18:45 PM »
Admin which is better the one of radioshack or the one of Compusa. Need to know because i am planing to use my last money on a good one and not on one that wont work to its best potential.
I don't have a windows Vista.  I have a mac with Windows XP but any program, hardware you put in it will work.
                              Thomas Edision.
« Reply #14 on: July 14, 2007, 07:09:27 AM »
Admin
If neither of them is the best. Can you tell me were did you bough yours.
Need to know.
                              Thomas Edision.
« Reply #15 on: July 14, 2007, 07:12:57 AM »
It was at a computer store, but I dont remember the name. I was in Boston for the weekend and had a robot contest a few days later . . . I needed the cable asap.
Try best buy, or the interweb.
« Reply #16 on: July 14, 2007, 07:16:41 AM »
                              Thomas Edision.
Offline Kohanbash
« Reply #17 on: July 14, 2007, 08:06:07 PM »
Hi
I have the one from radio shack and it works well, my only gripe is that it reinstalls itself and has a different com address for each USB port on my laptop that I plug it into. Also it is a little expensive (I needed it ASAP so I spent the extra money).
« Reply #18 on: July 15, 2007, 04:46:41 AM »
Thanks A lot.
Plus It only cost me $5.00 because they gave me something i didn't want and i gave it back and pay the difference.
                              Thomas Edision.
« Reply #19 on: July 15, 2007, 06:19:05 PM »
Ive bought the one on radioshack and it said that the disc has not been approved by windows. Like if it was a pirate disk. and that it can damage my system. Should  i Installed it?
Also it still does not show. Can somebody give me a picture of there $50.00 dollar robot. Underneath to see the weldings to see what i am doing wrong. If anything.
                              Thomas Edision.
What Am i Doing wrong?
« Reply #20 on: July 16, 2007, 08:52:01 AM »
Hello
I STILL doing the %50.00 dollar robot. And I have bought this new dongle but when i connect it to the computer and start up my robot. The computer does not show anything. I have a 5 Volt output to my dongle and it still does not work. I think the voltage regulator is not passing enough electricity.
What should i do?
I will post some picture of my robot. but my camera is not working so it may take until tomorrow. (today being Monday).
Pls post any answer. And yes i have installed the driver and the usb/ serial adapter is connected directly to the computer.
« Last Edit: July 16, 2007, 08:52:44 AM by robotvisionary »
                              Thomas Edision.
Re: What Am i Doing wrong?
« Reply #21 on: July 16, 2007, 09:12:01 AM »
How many bolt are supost to go throw the microcontroler. I have 4.66 volts.In the par of the LED.
                              Thomas Edision.
Offline Robotboy86
« Reply #22 on: July 16, 2007, 12:04:47 PM »
Typically mcu's take 5v's to run right.  Go get 6v batteries, run it through a 5v voltage regulator to the MCU?
Offline KambeiX
« Reply #23 on: July 16, 2007, 03:13:05 PM »
Some USB/Serial adapters won't work because in a normal serial connection you have TX, RX, CTS and DTR lines but in usb to serial sometimes you only have a level conversion for tx and rx lines.
If you have the schematic of the dongle you are using please post it. 4.7v should be enough
« Reply #24 on: July 22, 2007, 10:53:45 AM »
Which dongle?
How so?
What is your OS? Is it XP?
