Author Topic: trouble with programming AVRISP mkII  (Read 907 times)
Offline irveltasTopic starter
« on: February 07, 2012, 01:54:09 PM »
trying to modify servos but cant put in hex file. all i get is
Getting isp parameter.. SD=0x02 .. OKOK
Reading FLASH input file.. OK
Setting mode and device parameters.. OK!
Entering programming mode.. FAILED!
Leaving programming mode.. OK!
found some information on forum but with no technological background i cant understand how to fix it. if anybody has spare momment plz help.
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
Re: trouble with programming AVRISP mkII
« Reply #1 on: February 07, 2012, 01:55:31 PM »
What information did You find?
Offline joe61
« Reply #2 on: February 07, 2012, 02:04:31 PM »
What programmer are you using?
What programming software are you using?
What chip are you trying to program?
What board is your chip in, and what are the connections to the ISP headers (post schematic if possible)
Please copy and paste the exact error messages you're getting. We don't have much to go on at this point.
Joe
« Reply #3 on: February 08, 2012, 01:59:45 PM »
AVR ISP2
AVR STUDIO4
ATmega8 AVR
board as in $50 robot tutorial, exept first i biuld it for 10 pin programer so i had to change it as in schematic(atached), error message(atached). ty for help.
Offline joe61
« Reply #4 on: February 08, 2012, 02:06:49 PM »
What did the troubleshooting section in the help window say? I'm guessing that the lines aren't connected to the programmer socket correctly. Either a solder problem, or wires going to the wrong pins.
Failure to enter programming mode generally means either the SPI connection isn't working, or it can't drive the reset pin. Check the connections again, it's easy to get turned around when you look at the diagram from the top and then solder from the bottom.
« Reply #5 on: February 11, 2012, 03:13:12 PM »
joe61 u was right, problem was in reset line(poor soldering). but now im getting
Entering programming mode.. OK!
Erasing device.. OK!
Programming FLASH ..      FAILED!
and if i press verify i get
Reading FLASH ..      OK!
WARNING: FLASH byte address 0x0000 is 0x00 (should be 0x12).. FAILED!
were i should change it?
« Last Edit: February 11, 2012, 03:17:39 PM by irveltas »
« Reply #6 on: February 12, 2012, 07:27:43 AM »
isp frequency was wrong.
ty for help
Last post February 12, 2008, 12:26:36 AM
by entwicklungswalther
Last post February 26, 2010, 04:35:23 AM
by Finnik
Last post July 27, 2011, 05:36:35 AM
by Kirsty
Last post July 03, 2012, 02:59:21 PM
