Author Topic: Dangers of Soldering To Sealed Acid batteries?  (Read 769 times)
Offline SylvestreTopic starter
  • Helpful? 12
« on: February 07, 2012, 09:45:13 PM »
Hey guys,
I am going to have to be soldering a few wires (no current drawn obviously) to SLA batteries in a few days and I was wondering if there are any other dangers I should be worried about besides not applying too much heat from the soldering iron to the terminals too long.  I don't want to destroy my SLA batteries or me for that matter! x(
Re: Dangers of Soldering To Sealed Acid batteries?
« Reply #1 on: February 07, 2012, 11:21:45 PM »
Nope no dangers. Just don't use a cheap soldering iron, as that will (as you said) apply heat for too long.
Set your iron to max heat, and be quick about it.
  • Helpful? 12
« Reply #2 on: February 08, 2012, 09:40:26 AM »
Should I use the usual soldering method of heating up the terminal first and then applying solder or should I drop a blob of solder onto the wire and terminal?
« Reply #3 on: February 08, 2012, 10:25:48 AM »
Neither . . .
Attach the wire to the battery terminal before hand, and secure it well. Then as you you heat up both the wire and the terminal at the same time with the iron, hold the solder against the wire-terminal joint until it melts as desired. Make sure it melts securely on the terminal and not just on the wire.
Last post January 02, 2008, 09:07:58 PM
by HDL_CinC_Dragon
Last post January 23, 2009, 08:02:50 PM
by HDL_CinC_Dragon
Last post February 25, 2009, 11:12:58 PM
by SmAsH
Last post December 21, 2009, 08:12:58 AM
by waltr
