Author Topic: How to make gear for electric car ....??  (Read 583 times)
Offline RITESH29Topic starter
« on: February 11, 2012, 09:45:29 PM »
I am working on gear mechanism for controlling the two wheel at back of car with two DC motor of 24V .5HP......
so, no load RPM is 3000 i want to drive 15inch diameter wheel the front wheel are free. the required speed will be ~1meter/sec. not so fast
and RPM OF wheel at 100.
please help with these gear as worm have been constructed but the output at wheel is at 60RPM torque is very very less for driving the load of ~80kg.
Re: How to make gear for electric car ....??
« Reply #1 on: February 12, 2012, 12:08:39 PM »
A 15" wheel at 100 RPM will go ~2m/s
What is the loaded speed of the motor?
The unloaded speed doesn't say much, except that the gear ratio must be higher than 30:1, but not how much higher, so you need to find the loaded speed.
The two motors have 1hp total. In DK, a moped is limited to max. 1hp and 30km/h, with an adult rider and that's a bit over 8m/s, so you have ample motor power for 80kg at 1m/s (or 2m/s for that matter).
Last post January 26, 2008, 11:35:10 AM
Last post January 19, 2010, 07:39:42 AM
by madsci1016
Last post March 23, 2011, 10:58:05 AM
by nickc
Last post August 20, 2011, 02:12:25 PM
by DevinC88
