Author Topic: Will my Motor Driver Design 'splode?  (Read 345 times)
Offline BigKLaxerTopic starter
« on: February 13, 2012, 08:58:10 AM »
So I've been using two relay H-Bridge motor controllers I built for my 4WD Experimental Robotics Platform with one controller per side, but the motors are very unhappy at being instantaneously turned on and off, so I'm attempting to design a PWM H Bridge I can use for softer starts and stops.  This is my first attempt at designing a PCB so I'm looking for constructive criticism about how I can make this design better.  The pics of the schematic and board are below.  Let me know what you guys think!  Thanks!
Experimental Mobile Robotics Platform: http://www.udrobot.blogspot.com
Re: Will my Motor Driver Design 'splode?
« Reply #1 on: February 13, 2012, 12:06:31 PM »
Snubbers over the contacts (and a delay when changing direction) would help.
Unless you use PWM, it won't change a thing.
You could use PWM with a single MOSFET and a relay to achieve this as well.
The PCB would indeed "explode" the very first time you energized it  :)
You need wide, really wide, traces for the motor current and it's almost always a good idea to keep traces as wide as space allow.
If you post the .sch and .brd files I can clean it up for you, unless you prefer to do it yourself :)
« Reply #2 on: February 13, 2012, 12:53:24 PM »
I'd rather just upgrade to MOSFETs entirely since relays have a shorter life and take more energy.
I learn better by example  ;D but if you could, can you inform on the process so I know for next time?
« Reply #3 on: February 13, 2012, 05:10:48 PM »
Seems I promised more than I could keep. Tried under Eagle 5.4, 5.7, 5.11 and 6.1, but they all break (close completely) as soon as i try to route the traces :(
Things to note, apart from the trace width (plenty of trace width calculators on the web, to find the minimum required width for a given current), is that you need basis resistors for Q3 qnd Q4. You need fast (reverse biased) diodes over each MOSFET and you need a large buffer cap on the motor supply.
If you want to use SMD caps over the motor terminals and the logics supply, I'd recommend a larger size, as it's too easy to short the small ones (due to the small pad distance).
The cap on the motor terminals will have much more effect if mounted on the terminals of the motor.
Unless you prefer a double sided PCB, either use through hole components or change the libraries to place the SMD's on the bottom layer.
Last post March 31, 2007, 07:07:03 PM
by sdk32285
Last post July 04, 2008, 09:29:48 AM
by Steve Joblin
Last post September 25, 2008, 05:48:02 PM
by Ro-Bot-X
Last post October 06, 2008, 04:24:36 PM
by javafiend
