Author Topic: prob regarding legged robot  (Read 1492 times)
Offline nikhildTopic starter
« on: July 12, 2007, 12:56:28 AM »
hi,
m building a 4 legged robot robot and wanted to know that for the legs could i use geared dc motors/dc motor instead of servos.what are the advantages of servos over geared dc?pls help as i m a beginner
Offline nehak
Re: prob regarding legged robot
« Reply #1 on: July 12, 2007, 09:53:23 AM »
i've d sme querry... pls help.. evn m a beginr..
also i wnt 2 ask hw many motrs wil b reqd per leg 4 a robot dat cn walk st. n also turn left n rite n cn also turn bak in case it hs al 3 sides blokd.. pls help asap...
Offline KambeiX
« Reply #2 on: July 12, 2007, 10:02:20 AM »
before building legged robots you should read at least a little about degrees of freedom, that will pretty much clear how many servos you need for each leg.
for a toy robot that can turn and walk you can even start with 1 servo/leg but I think you will get good results with 4servos/leg. The problem is, 4 servos require a complex logic and you must be able to program that.
Also, the difference between a servo and a geared dc motor is that with the servo you can specify the position for each motor. With a geared DC you can only make it turn.
« Reply #3 on: July 12, 2007, 12:46:06 PM »
Servos come with gears and control electronics while DC motors usually do not (if it did, then it would be a servo).
The main advantage to a servo for a walking robot is that it already has built in position control done for you.
nehak, I recommend reading these links:
http://www.societyofrobots.com/robotforum/index.php?topic=602.0
http://www.societyofrobots.com/robotforum/index.php?topic=1480.0
(they should help you)
Last post January 23, 2009, 11:14:16 AM
by die-0dd
Last post September 02, 2009, 12:41:38 AM
by Webbot
Last post November 14, 2009, 04:38:27 PM
by SmAsH
Last post January 25, 2011, 08:02:53 AM
by Mike136
